Go to Post make sure to make it look really cool, it makes it easier for teams to remember you, which comes in handy for alliance selections ;) - Holtzman [more]
Unread 01-03-2009, 16:27
dboisvert dboisvert is offline
AKA: Dan Boisvert
FRC #2405 (Divided by Zero)
dboisvert is an unknown quantity at this point
DS Digital Input/Output
Recently my team went to a competition and I asked for help with out driver station. We had purchased a few Light Switches from the local hardware store and I had no idea how to wire them properly.
So he helped me wire them properly and connect them to DS 1 and 2 on the Driver Station and now I need to figure out how to code them.
My current code looks like this
bool switch1;
switch1 = m_ds->GetDigitalIn(1);
printf("Switch Value is: %d  ", switch1);
I never got to look at the code extensively during the competition but as far as I know it printed out all 0's when the switch was in either position.
My next problem is we want to wire in a few LED's to the DS so we know what is going on with the robot
m_ds->SetDigitalOut( 1,true);
I know how to wire the led's but I need to know if this is the proper syntax to turn them on.
Unread 01-03-2009, 16:55
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Re: DS Digital Input/Output
I'm not sure about the switch problem, cuz i was experiencing the same thing. However the if m_ds is a pointer refering to digital out on the ds, then that code should work. I didn't have any problems with the LEDS.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 01-03-2009, 17:33
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
A couple of suggestions:
1.Your printf is set to print an int, not a boolean. I don't think there's a flag for boolean, so you might want to change it to use two different printfs depending on the state of the variable
2.Check your switches with a multimeter and make sure current is actually getting through.
3.Check your digital outputs and see if you're actually turning it on. If you are, chances are that you have reversed the polarity to the LED(LEDs are diodes, so they only work one direction)
Get yer robot source code here!
Unread 01-03-2009, 18:59
AKA: Dan Boisvert
My next best guess for C++ would be a "c" character flag? If im not mistaken it would print a t or a f then correct?
Unread 01-03-2009, 22:32
Originally Posted by dboisvert View Post
So he helped me wire them properly and connect them to DS 1 and 2 on the Driver Station...I never got to look at the code extensively during the competition but as far as I know it printed out all 0's when the switch was in either position.
There seems to be a lot of confusion about what "wire them properly" really is. I think the software looks right, so maybe the hardware isn't. What sort of light switches are you using? How are they wired?
Unread 01-03-2009, 23:41
AKA: Dan Boisvert
I cant get my hands on the light switches right now but I know they have 3 wire leads. I remember him telling me something about "Getting around having to use a resistor" and Double Pole Double Throw
Thanks for all of the help so far!
Unread 02-03-2009, 21:03
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
printf("%i", true); will print 1
and printf("%i",false); will print0
you dont need a bool printf flag, or a if statement
just use the int flag (%i or %d)
Watchdog.Kill();
Unread 02-03-2009, 22:09
AKA: Dan Boisvert
It must be in the wiring in the switch then because I have tried that.
Unread 02-03-2009, 22:42
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
We experinced similar trouble. Wire a 1kOhm resistor between the power and signal wires on the switch. That should solve your problem.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 07-03-2009, 03:32
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
I have a question on the jumpers also, my code looks like this:
enum{
   ARCADE_MODE = 1,
   ENABLE_AUTONOMOUS = 2,
   DRIVE = 3,
}jumpers;
void OperatorControl(void)
   while(1)
      if(ds->GetDigtalIn(DRIVE)==1)
         myRobot->TankDrive(-rightstick->GetY(), -leftstick->GetY());
      else
         myRobot->Drive(-leftstick->GetY(), -rightstick->GetX());
This isn't really for competition reasons, except for merely trying to get the jumpers to work. When I don't plug in the jumper it drives like how the else statement is written, but when I put a jumper on jumper pin#3 on the driver station it doesn't go at all, and I've tried restarting the driver station and robot, and still same results, what is going on here? (I have counted the jumpers many times to make sure it was on the right one)
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 07-03-2009, 11:56
DonRotolo's Avatar
Back to humble
FRC #0832
Explain which pin 3, there are a few of them, and the jumper goes from where to where exactly?
Unread 08-03-2009, 17:50
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
I've been using a really simple program to display my driver station inputs to the driver station LCD panel. C++ sources/project included:
http://www.virtualroadside.com/blog/...-test-program/
Digital Input? boris C/C++ 1 30-01-2009 14:51
Switch digital input to output during operation? Parallax Ultrasonic wt200999 C/C++ 2 28-01-2009 19:30
live input/output to/from application MarkH Programming 3 06-04-2006 01:43
digital output frequency Barth Programming 8 06-03-2005 21:58
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
