Go to Post You can't just leave us hanging! That was SOOO 2010! - nighterfighter [more]
Unread 07-03-2009, 16:37
unobtainium-42's Avatar
unobtainium-42 unobtainium-42 is offline
Team President
AKA: Eric Eaton
FRC #0670 (Homestead Robotics Team)
unobtainium-42 is an unknown quantity at this point
No robot diagnostics
I got serial to work with a COM pot ton my pc. When I run a debug launch the processor says this:
program
Exception current instruction address: 0x012d4744
Machine Status Register: 0x0008b032
Condition Register: 0x20000008
Task: 0x12ef170 "FRC_RobotTask"
0x12ef170 (FRC_RobotTask): task 0x12ef170 has had a failure and has been stopped
0x12ef170 (FRC_RobotTask): fatal kernel task-level exception!
Earlier in the year I was using debug to monitor the robot, but that no longer works. Debug launches stop in the member declaration and promptly terminate, sometimes with errors, and never touch any of my breakpoints. Run launches just terminate immediately (sometimes with error). Fortunately, I can still program the robot with the FRC downloader.
Can anyone help me solve this problem?
Unread 30-03-2009, 16:20
foemill's Avatar
foemill foemill is offline
What do you mean it's overweight?
AKA: Eric Miller
FRC #1270 (Red Dragons)
foemill is on a distinguished road
Re: No robot diagnostics
I've been having the same problem. Have you found the cause yet?
Unread 30-03-2009, 21:23
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
serial? Com? what for? why not just use the target console?
Watchdog.Kill();
Unread 31-03-2009, 09:50
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
program
Have you tried deleting all your old launches and recreating them?
Not sure that will work, but seems worth a try.
Robot-to-robot and robot-to-trailer GaryVoshol Rules/Strategy 11 06-01-2009 19:18
CMUcam2 Serial Port Diagnostics Kevin Watson Programming 13 18-02-2006 15:05
Breaker Panel Diagnostics dm0ney Programming 4 29-03-2005 19:00
Infrared Beacon and Sensor Diagnostics Code Released Kevin Watson Programming 3 25-02-2004 17:50
Robot Gallery from the 2003 robot expostion in Tokyo, Japan Andrew Rudolph Chit-Chat 1 04-12-2003 15:22
