Go to Post If this photo doesn't tell us why a photographer is important to a team, I don't know what will. - JaneYoung [more]
Unread 02-03-2009, 19:50
Dr. Manhattan Dr. Manhattan is offline
Atomic Reconstruction
AKA: Joe Bakke
FRC #2521
Dr. Manhattan is on a distinguished road
Send a message via AIM to Dr. Manhattan
Wiring a boolean switch.
We have a basic toggle switch on our bot, wired to the DIO. The switch bridges the power and signal lines, is this how it should be wired?
Unread 02-03-2009, 19:59
Re: Wiring a boolean switch.
No.
It should connect ground and signal one way and nothing at all the other way.
+5v power is not used for a basic switch.
Unread 08-03-2009, 11:26
Integral Integral is offline
AKA: Ross
FRC #1130 (Robo Rebels)
Integral is an unknown quantity at this point
On our DS I found that I could not get a reliable signal if I just let the signal line float. You need to hold the signal high through a pull up resistor. Solder a 1k resistor to the 5V line, then the free end of the resistor to the signal and 1 side of the switch. Ground the other side of the switch. When the switch is open you will have a solid High signal, when the switch is closed a good low.
Pressure Switch Wiring idahorobot Electrical 1 27-01-2007 11:18
IR Switch Wiring sgsdragons Electrical 2 14-02-2006 03:26
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
Wiring Nasson switch ten3brousone Pneumatics 4 19-02-2005 17:16
Wiring a switch stevex Electrical 3 16-02-2005 08:31
