Go to Post Doesn't matter what you use if you can't drive it. - efoote868 [more]
Unread 08-03-2009, 13:37
grim's Avatar
grim grim is offline
Inventor Guru
AKA: Todd
FRC #0549 (Devil Dawgs)
grim is on a distinguished road
Re: Wiring / Pneumatics
That is still pretty vague. But I will try to point you in the right direction as briefly as possible.
First, to use the electrical features of Inventor you will need to be running either Inventor Pro or Inventor Routed Systems. With the other versions you can see the electrical data but you cannot edit it.
Second, open the part you wish to wire to in part mode. Unless a part is authored for electrical use you cannot run wires from or to it. On the panel bar title bar there is a pull down next to where it says "Part Features". Pull it down and select "Harness Part Features". This gives you access to the tools you need to set a part up for electrical use. Two things need to be done to the part.
1. Add a pin or pins with a unique number. Pins can be placed on work points or by selecting a cylindrical surface.
2. Go to Harness Properties and add a RefDes such as U? that will be replaced later when you start wiring. Don't worry about it if more than one part has the same RefDes.
3. Go to connector authoring tool and author the part and save it.
Third, you can now open the assembly and select create harness from the Assembly panel. Now walk through the Show Me animation in the Help file system.
When the dialog pops up to select your wire you can either rename the wire id or use the default. Under catagory I would select generic unless you know specifically what manufacturers wire you are using and then select the gauge and color for the wire you wish to run. This will create a point to point wire run in a straight line.
The cable tool allows you to create a multi-wire cable and the segement tool lets you create a spline like object that you can route wire through using the route tools. Think heat shrink or corregated tubing for segements.
Good luck!
"Does fuzzy logic create lint?"
Wiring/ Pneumatics paigetee Inventor 0 10-02-2009 16:28
wiring? SPARKY1688 Electrical 4 31-01-2005 17:44
Wiring Pneumatics Switch Simpson Pneumatics 3 11-02-2004 12:32
wiring. archiver 2001 1 24-06-2002 00:07
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
