Go to Post Don't forget to stock up on luck. You'll need some of that too. - Molten [more]
Unread 08-03-2009, 14:23
Ben87 Ben87 is offline
FRC #0087 (Diablo)
Team Role: Driver
Ben87 is a jewel in the roughBen87 is a jewel in the roughBen87 is a jewel in the rough
Re: Why Hasn't first gone Brushless?
I understand the cost Of it, not saying that they would need to be supplied in the KOP, but why not make them legal. I dont see anyone complaining about the cost of the cRio's....
They aren't cheap either but everyone benefits from them
At only 337watts the cim motor is not THAT powerful of a motor.. The Brushless system of my Brushless rc car puts out more then double that. If you wanted something comparable to the cim in brushless form, it would be half the size and the only thing needed to use it are shaft adapters which can easily be made.
As for price, Not every system you look at is that expensive
http://www.hobbycity.com/hobbycity/s...idProduct=7392
Take for example, that motor 30 bucks, and rated for double the power and more then the cim.
Before everyone jumps to conclusions about price and effectiveness, do some research- things are always not as they seem.
Unread 08-03-2009, 14:42
Billfred's Avatar
Billfred Billfred is offline
Historically, FIRST hasn't allowed non-kit motors. The lone exceptions in recent years have been for the CIM motors, where two were provided with the kit (and a total of four would be legal). I'm sure someone with more time under their belt can expand on the idea behind that decision.
The CIM motor is powerful enough to power nearly any manipulator a team could need, and more than powerful enough to tackle a person (or whack them in the chin--don't ask). If it's enough to let us send a robot screaming downfield at upwards of 10 feet per second, do we really need more power? Also, never rule out the importance of those shaft adapters--someone has to make them, and that takes money.
Also, perhaps someone can enlighten me about this: how durable are these motors compared with motors currently in the kit? Sure, they might be more powerful--but that's no good if they burn up when stalled for a tenth of a second, or are particularly intolerant of abuse during assembly and testing. I missed out on the brushless era in R/C trucks (I quit racing when I went to college), so I'm unfamiliar with the state of the art these days.
Unread 08-03-2009, 15:26
Johnny's Avatar
Johnny Johnny is offline
We do it for the pizza
FRC #1266 (The Devil Duckies)
Johnny has a spectacular aura aboutJohnny has a spectacular aura aboutJohnny has a spectacular aura about
The motors provided in the KOP's are fine and easy enough to deal with. The fact that the motors and accessories are under so much restriction is a plus in my opinion because it's one elss thing that a team has to worry about. We just need to learn how to deal with the restrictions and constraints. Plus, it makes things much more fun and interesting
Unread 08-03-2009, 16:28
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The problem then is, as pointed out by multiple people earlier in the thread, it widens the gap between the "have" and "have not" teams. Motors have typically been (aside of additional CIMs and spares) provided in the KoP and teams have only been allowed to use the provided KoP motors. This ensures equality, as well as helps teams learn how to effectively use provided resources.
Nobody hear said that the CIM is that powerful, but it is powerful enough for virtually any FIRST application. Even in carpeted games, a two-CIM per side drivetrain through a transmission can produce more than enough force to break traction wheels loose from the floor. Once you surpass your static friction, additional force doesn't do much good.
The motor alone isn't the only thing that adds cost to a brushless motor. Teams would then need to buy addition speed controllers (though usually in the same ballpark as jaguars and victors) for their new non-KoP motors.
What voltage is the motor you linked to designed to run at? The one I found was designed for 10.5 and put out comparable numbers to a CIM, although was significantly more expensive.
Unread 08-03-2009, 18:09
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
here is a similar question.
why hasnt FIRST used 12v 18Ah lipo batteries?
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 08-03-2009, 18:23
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Fire = bad
-Greg
Unread 08-03-2009, 18:57
Please direct me to some 12V 18Ah LiFePO4 batteries that aren't cost prohibitive. Note our discharge rates!
Unread 08-03-2009, 20:08
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
i noticed someone mention that they would to like to see stepper motors before brushless motors. it was my understanding that brushless motors were just stepper motors with fewer steps, could someone enlighten me if i am wrong
Jason
Unread 08-03-2009, 21:12
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
Originally Posted by Greg Peshek View Post
Fire = bad
-Greg
indeed (:
id like said batteries too, ive been looking for some cheaper-than-an-arm-and-a-leg lipo batteries too ):
RPI 2012
BREAKAWAY
Unread 08-03-2009, 21:17
FRC #0087 (Diablo)
Team Role: Driver
Yes stepper motors are very closely related to Brushless motors, Both use digital current switching over brushes and commutator. Without the brushes, there is nothing that can wear out in a brushless motor also.
For those who dont know what a brushless(non outrunner) motor is, here is a really breif look at them. In the Layest(new word?) of layman's terms a brushless motor is a brushed motor flipped inside-out. the windings usually found on a brushed motor's armature are replaced by a permanent magnet in the brushless motor. Windings(stator) in a brushless motor are bonded to the inside of the motor can.
Since the current switching of Brushless motors is handled by the speed controller, the commutator, brushes and all associated components arent used in them.. the only moving part is the rotor. Brushless motors are 99% maintenece free.
A note on efficiency from an Industry Leader, Castle Creations
The efficiency of a motor determines its quality. Higher efficiency means better design and high quality components. The higher the efficiency of the motor the more power it can produce before it overheats. Here’s a little math, we promise it won’t hurt. Say you are laying down 1,000 watts, (about 1 ¼ horsepower), and your motor is 70% efficient. That means you are turning 300 watts into heat. Ever grab a 300 watt light bulb? If the motor is 85% efficient it only burns 150 watts as heat. More power goes to the wheels and the motor runs cooler and able to put out even more power when needed.
Unread 08-03-2009, 21:54
sparkscarz's Avatar
sparkscarz sparkscarz is offline
FRC #1219 (Iron Eagles)
sparkscarz is an unknown quantity at this point
Send a message via MSN to sparkscarz
yea ithink i would say cost too because brushless is a lot
and frist is a non profit ..
.::S::: P:::A:::R:::K:::Y::.
Unread 08-03-2009, 22:22
Ben,
All things being considered, the brushed motors are the best choice for our competition. Maintenance free is not a problem for this competition since the service life is measured in hours not months. Not one team I am aware of has ever failed a motor due to brush wear or bad bearings other than those over stressed by bad design. Controllers for brushless motors tend to be more complex and vary with the design of the motor, i.e. how many poles/phases need to be controlled. Brushless motors have a bad tendency to lag under heavy loads. Brushless motors tend to be better for fixed applications like fans, video recorder head wheels and other applications that require some sort of phase lock or rotation lock. Stepper motors can be a better choice for some of our applications but again controllers become very complex. All of these motors reguire some form of feedback to operate and change speed and so control then lies outside the ability of most rookies and those teams with few mentors. IMHO, brushed motors and speed controllers still give us the most level playing field and are the easiest to implement for the majority of teams.
Unread 17-03-2009, 12:59
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
as a owner of over $2000 of brushless motors, i dont think its a good idea for a few reasons
1. Need to pay MUCH more attention to gearing/heat/ etc. 90% of brushlesss motors need to be kept at about 45k RPM. Close monitoring of motor and ESC temperatures must be read and translated.
2. Cost. Yes there are $30 brushless motors, but those tend to have magnet separation. the FIEGO XL is a $60 motor but IMHO the only motor worth it is the NEU series motors at $300 each! Either way, MUCH more expensive. The economy is not in good shape, FIRST needs to stay afloat!
Lipo batteries ARE THE WAY TO GO!!! I run 12s setups giving more that 48V of power and iv never had a problem....but that dosnt mean someone that dosent know what they are doing wont catch one on fire because they didn't read the instructions...
NOT TO MENTION the cost of a LIPO charger?! Mine costs $270....and people have to learn how to use em, balancer taps are a mysterious thing for anyone who have never used em
Basically im saying YES it would be AWESOME if first went LIPO and BRUSHLESS, but it dosent make sense right now
Unread 17-03-2009, 13:09
Jared Russell's Avatar
Taking a year (mostly) off
Stepper motors would be SWEET. Position control without having to install yet another encoder and write yet another PID loop?
Sign me up.
Unread 17-03-2009, 14:05
Andrew,
LIPO batteries will catch fire in the hands of teams who regularly damage the AGM cells we currently use. Fire on the field is not something I want to be a part of.
Jared,
Stepping motors and feedback are not mutually exclusive. You have to know where you are in order to control where you want to be.
Why we love FIRST!!! nevereverregret General Forum 9 11-12-2008 07:21
pic: 614 hasn't tipped yet. EHaskins Extra Discussion 3 09-10-2006 16:33
Why FIRST is important... Joe Johnson General Forum 7 23-05-2006 14:22
If anyone hasn't noticed.... archiver 2000 5 23-06-2002 22:41
So you do FIRST..... Why? Kate Leach General Forum 44 02-07-2001 08:55
