Go to Post What isn't fun about watching a robot hang tubes? I love watching my team do it! - Michael Corsetto [more]
Unread 08-03-2009, 18:03
gbzalla gbzalla is offline
FRC #2551
gbzalla is an unknown quantity at this point
Max RPM for drive motots?
Our team is in the process of calculating our autonomous movements, and after determining the necessary distances through painful calculations all we need is the maximum RPM for the default CIM drive motors.
So if anyone knows the maximum RPM for the 12V CIM motors that come with the KOP please reply! Thanks!
Unread 08-03-2009, 18:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Max RPM for drive motots?
About 5300 rpm, with no load.
Unread 08-03-2009, 18:06
Seat Ninja's Avatar
Seat Ninja Seat Ninja is offline
Still waiting for the boltstretcher
FRC #0686 (Bovine Intervention)
Seat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of light
Send a message via AIM to Seat Ninja
Here's a link to a page with all kinds of specs
http://banebots.com/p/M4-R0062-12
Can you play Crysis?
Unread 08-03-2009, 18:09
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The max RPM for the CIM motors running under no load is approximately 5300rpm. This will be lower under load, and your actual speed will vary depending on your exact set-up and how you code your drive.
Especially given the low traction surface and the chance for your wheels to "spin out" if you surpass the static friction, I'd highly suggest trying to create a closed loop system if at all possible.
Unread 08-03-2009, 18:26
FRC #2551
Thanks for the answers everyone. That's very helpful for our autonomous calculations.
Unread 08-03-2009, 18:34
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
You aren't going to get the right distance without a very good feedback system.
Things that will affect you.
Temperature of CIM.
Victor or Jaguar Quality
Battery Voltage
Chain/Belt Resistance
Wheel Slippage
Metal Binding
other problems.
I suggest that you do not try and make an autonomous code that goes exactly the right distance. Make a code that puts the robot at least 5 feet past your target.
Just trying to be helpful.
maximum rpm for encoder. windell747 Sensors 6 31-01-2010 14:19
Wanted: CIM RPM data For actual robots de_ Motors 8 12-04-2008 20:07
what is the max for.... Alex Cormier Kit & Additional Hardware 2 13-01-2003 21:14
Special Pricing for 3DS Max? Kevin Thorp 3D Animation and Competition 4 02-12-2002 22:11
Drill Motor Max RPM with Gearbox? archiver 2001 1 23-06-2002 22:40
