Go to Post I just turned 51 and I'm still not sure what I want to be when I grow up! - Mike Betts [more]
Unread 08-03-2009, 18:42
Spyder Tom 1622's Avatar
Spyder Tom 1622 Spyder Tom 1622 is offline
AKA: Tom Chenier
FRC #1622 (Team Spyder)
Team Role: Human Player
Spyder Tom 1622 is an unknown quantity at this point
Pinning Long Robots
I just witnessed 2543 Titan bot, a wide front robot and a defensive robot for the winning alianace at the San Diego regional, pin the two top rated scorers 968 RAWC, and 1538 holy cows that were both skinny front robots. They were the reason this alliance one because they drew away the other scorers to help get them out of the struggle.
((TOM'S ADVCICE) long robots get pinned easily by wide robots due to the hitch differencial so pick well in the finals and if they get stuck their is almost no way to get out of the snag).
I was just wondering if anyone has any ideas or strategies to fight this innevitable struggle.
Thanks,
TomTom
http://teamspyder.org
Unread 08-03-2009, 19:07
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Pinning Long Robots
Stay off the walls/corners and learn how to drive when being hit from the side. Watch the driving at Kettering espeicially in the finals. There are some very good robots that are very good about not getting pinned. There are others that are very good at pinning.
The technique for not getting pinned in the when hit in the middle is a little counter-intuitive. The "initially logical" way will actually get you pushed straight to the side and then pinned against the wall. The other technique usually will help you get away as long as the other bot is not significantly faster.
I am going to leave this one a little open for others to contemplate. Feel free to post the solution if you figure it out. I want to diagram the physics of this technique as it is a really neat and "counter intuitive" thing.
Unread 08-03-2009, 19:11
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Wouldn't you just let go of the sticks? .. and if that doesn't work turn into them? (if you can get traction) That's my first response to the situation..
I haven't had the opportunity to be under heavy defense yet, so I'm not sure.. Can't wait for LA
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 08-03-2009, 19:15
AKA: Tom Chenier
IKE where can i find any footage of the kettering event?
Unread 08-03-2009, 19:19
Cascade Cascade is offline
Intermittent Mentor
Cascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to beholdCascade is a splendid one to behold
Try here: http://www.thebluealliance.net/tbatv...hp?eventid=238
The videos' are not yet posted, however.
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
When you say "middle" do you mean the geometric middle of the robot? If so doesn't the answer to your question depend on the center of mass of your robot (among other things).
Assuming your center of mass is behind the center of your robot (as ours is) it seems like you would want to reverse the side away from the pinning robot adding to the rotational moment they are providing.
Brad, "turn into them" is a little vague. For our robot turning towards them by powering the far side forward will result in canceling the moment and us getting pinned. Reversing the far side will add to the moment and spin us around, likely letting us escape. Both of these maneuvers are trying to turn our bot towards the pinner, but only one will work.
Last edited by Vikesrock : 08-03-2009 at 19:26. Reason: Clarified wording, initially asked if middle meant middle
Unread 08-03-2009, 19:22
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Watching both Kettering and the SD webcasts, I can tell you that 2543 was a different breed than the defensive bots in Kettering. No offense to the defensive or offensive teams in Kettering, who both did outstanding jobs, but 2543 did it better.
They would hit 968 perfectly so that the contact could not be avoided or escaped from after initiated. They would often hit them in a wide-open section of field, no other bots or walls nearby. Then they would push them all the way into the wall (often halfway across the field) and hold them there.
Their pins on 1538 weren't quite as pretty, but combined with the traffic generated by alliance partners and the corners, they made it almost impossible for 1538 to score.
Unread 08-03-2009, 19:30
.999~=1
Originally Posted by Vikesrock View Post
When you say "middle" do you mean the middle of the robot? If so doesn't the answer to your question depend on the center of mass of your robot (among other things).
Heh, true. Well the pinning motion I believe is being described here, after watching san diego, is where a wide robot gets inbetween your trailer and the back of your robot. The initial reaction would be to try and "turn away" (to the right in the shown picture) or drive straight to get into it. But you would want to turn left, pushing your trailer into them, allowing you to eventually speed out of it. I also believe letting go of the sticks completely will help, because if your opponent ever stops accelerating you will be let free, and will have to accelerate at that point. Then again whoever is pushing you should never let go.
Unread 08-03-2009, 19:41
Smoores's Avatar
Smoores Smoores is offline
AKA: Steve Moore
FRC #2272 (Metalheads)
Team Role: Student
Smoores will become famous soon enoughSmoores will become famous soon enough
i can't wait either! hope to see you there!
Aviation in itself is not inherently dangerous. But to an even greater degree than the sea, it is terribly unforgiving of any carelessness, incapacity or neglect.
2007 Championship Highest Rookie Seed - Galileo
2007 CA Rookie All-Star
2007 CA Highest Rookie Seed
Unread 08-03-2009, 21:19
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
It seems to me that turning right into the pinning robot would be the thing to do to break the pin, especially if the pinning trailer is in your path to the right. If you turn to the left, you will be driving your trailer into them and they would push back on it and pull you back into the pin.
Unread 08-03-2009, 21:26
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
I meant getting hit in the middle of the regolith.
Bingo.
here is my take on it. For the record we have a crab drive and do a slightly different manuever, but essentially this works .
If you try to turn away from the attacking bot, the trailer wedges against theirs. At this point you trying to turn your bot (highest energy action), your trailer and their bot. Meanwhile your opponent is just trying to drive you sideways. The appearance on the field is a magic hit and then you get pushed across the field into a wall.
If you turn into their bot, your forces are opposing theirs which keeps you in place (center of regolith). It also causes your bot to rotate around theirs, and theirs to rotate about yours. As the speed of rotation increase, you will slip away (unless they are way faster), and your trailer will swing around the front of their bot and break loose.
Check out early 33 videos for what not to do, and then the last qualification match (towards the end) for a into the skid example.
Now the downside of this manuever is it exposes your trailer to the front (business end) of most robots. This will often result in a ball or two in your trailer, but that is better then the pinned and filled routine.
This principle also explains why it is so hard to turn off of the wall.
Unread 09-03-2009, 21:32
TITANSTEELDSTRY TITANSTEELDSTRY is offline
FRC #2543
TITANSTEELDSTRY is an unknown quantity at this point
That didn't work against us, because like you said, our robot's really really fast, and only a few pounds under the limit, hah.
Unread 09-03-2009, 22:09
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
The key to avoiding defense is just that, avoiding it. Because of the low friction surface even impacts can throw you off a great deal, and pinning is deadly since you can't count on a strong drive to break free. Also if you're team is super high scoring, and the other alliance doesn't also have a super high scoring bot I would suggest sending your own defensive bot to deal with the one playing on you.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 10-03-2009, 08:56
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Huh. You guys wouldn't know anything about that now would you. 910 was quite deadly if left alone hence, don't leave them alone. Very nice bot guys.
Unread 10-03-2009, 09:57
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Bingo.
Why not just drive backwards? The inertia of the defending bot will take it with you and turn it to its left, freeing you to do as you please.
Also this depends on your proximity to the wall. If the wall is directly to the left in this drawing, you're in a bit of hurt.
Hi!
Best Pinning Robots You've Seen so Far Akash Rastogi Technical Discussion 22 03-03-2009 18:44
Is pinning opposing robots trailers allowed? spiffyspleen Rules/Strategy 22 05-01-2009 16:47
Pinning a Mechanism Rob2713g Technical Discussion 5 30-01-2008 13:11
Clarification on Pinning Stu Bloom Rules/Strategy 2 15-03-2006 05:07
Ramming/ Pinning f22flyboy General Forum 21 07-03-2003 20:39
