Changes to rules mid-event? Rochester Regional
Good Evening-
While we were impacted one one of these this became a discussion with several other teams- and clarification, while final for the event, did not sit well. Thus: 1) If a human player illegally retrieves an empty cell from the playing field by breaking the plane (-10 points) why is the cell not confiscated? Said player can still exchange the cell for a super cell- and thus is rewarded by +5 points should the cell be scored. 2) If a robot is DQ'd from a match at the conclusion for an illegal starting position or starting outside of the bounds, why are the points that the team scored not subtracted? (I understand the logistics of this one). 3) We watched a field reset because all 6 teams started throwing balls into the court at '3-2-1- GO' instead of the tone. No penalties were assessed (should have been -20 or -30 per side). Earlier in the day we watched 3 teams pick up 10 point penalties for getting a ball into the court at '3-2-1-GO'. Perhaps, in the future, this should be set up similar to a drag race- No announcer, just a tone. 4) Teams (forgive here) 145/1450/1405 (pick two) were playing on the same alliance. Team A was told they were being bypassed and could not touch their control station for some reason. Team B, having similar numbers, was the intended target of this statement by the field personnel and blithely tried to get their robot to go- while it just sat there. Thus two robots on the same alliance sat through the whole match. Instead of terminating the match immediately an offer of 10 points for the 'error' to the score of the next match was made... which was negotiated into a complete rematch. The other alliance still won... but this sort of case is not covered *anywhere* in the rules when a field communication error results in a non-play event. 5) Ahh- Battery Voltage. Our team was told that Control could not read our battery voltage and we would be 'bypassed' if it happened again- and we would not be allowed back on the floor to power cycle the robot nor would any of the refs undertake said action. After strong urging of the students to immediately open up a negotiation with the referees (we did not have a spare module) they offered to allow us to pass if the voltage was displayed on our DS. In all cases the voltage was displayed to the user- and in all cases the robot functioned correctly in all modes of the competition. There was never a repeat issue with the voltage. I re-read the cRio notes (lost the link just now) but 3.1.8? in the manual stated that there is a known issue with the communication just dropping out. Now, call me old fashioned, but when there is a known bug in this manner... shouldn't there be a bit more flexibility here? This was an awesome game out there- I could not believe how the pits exploded to accommodate the extra 16 teams- it was great to have all of you here in Rochester. We really must do a home-exchange to help attract more teams... hotels are expensive! Jason Last edited by purduephotog : 07-03-2009 at 22:27. Reason: Remembered the last issue |
Re: Changes to rules mid-event? Rochester Regional
How many of these are actual changes to rules mid-event (as the topic says) and how many are you thinking the rules should be different? I think there is a big difference between the two.
In any case, I agree with John that this thread is more about rules you disagree with and bad experiences you had, rather than anything changing mid-event. |
Maybe this is just because I know a lot of the people that were running the show and have a bunch of the inside scoop... but I think this regional was run very very well. The crew had some tough things to deal with, but they did everything they could to make the fair and correct calls. As much as I can tell rules were followed well and the field ran smoothly thanks to a lot of hard work. There are always a few hiccups, but thats normal. And it seemed like a lot of the teams were very very patient and understanding. Everyone knows the troubles we have all faced with the new control system and in my mind everyone was incredibly gracious in working with the volunteers and staff to help the event run well. |
Ya we had a match where us and an alliance member would not move but there was no effort to redo the match But it seemed like once this started happening repeatedly to the same two positions, they started redoing matchesbut at the same time... "There were a lot of issues that were technically the fault of the teams (faulty code), but without a lot of controls or programming background, many of the teams might not have seen them." that is true also, esp, where we were, with watch dog, one second it would be fine the next it would be going psycho... Last edited by Hanna2325 : 08-03-2009 at 09:20. |
Regarding DQ for a robot not in the correct starting position.
It is the responsibility of the HEAD REFEREE to assure that all game elements and robots are in the proper starting position before the beginning of the match. The match will not begin unless all robots are properly aligned/positioned. It is impossible from the rules to be DQ'd for not having the robot in the proper starting position. |
#7
Hi Kim! (And others!)
I'm sorry- I didn't mean to imply the regional *wasn't* run correctly- I believe it was run with an excellent vision towards speed and efficiency in a trying set of circumstances. As I said the only 'impact' (to us) was the cRio battery voltage issue- and it didn't result in a DQ or bypass. The tone of the conversation was that it was up to the students to prove their hardware was functioning properly- but they would not be allowed to do so by asking the ref to verify the voltage on the DS, nor would they be allowed any access to the tools to do so since they would not be allowed back out onto the floor once the crater was set. In fact the only way to test that the field couldn't read the voltage was to go out on the field- which was attempted at lunch but denied. That leaves the DS as the only indicator that voltage is being relayed correctly... but that the field was at fault. You can see the set of contradicting situations here I hope. John- I believe the field varied their reports on my points #3, #4. Just because the announcer was significantly early on GO with all teams offending is no reason not to assess the penalties. Touching the ball before the tone is a penalty (although I would argue that touching is not possession as referenced in G40A) As for #4 there was 'hope there would be time for a re-match' as the official word. That was translated as "We're putting the schedule (<T16>) ahead of what is right". A mistake was made and until the very last match of the day there was still no idea whether or not a rematch would be performed. That acknowledgment of a field fault occurred yet the match replay was not a foregone conclusion. Joey- I'll admit your logic is superb here- but given the voluminous rules that detail nearly every situation- I'm surprised this isn't spelled out as acceptable. From what I heard of other conversations with the refs there was going to be a QA determination after the regional to decide if this was a legal activity. My point, albeit slightly rambling, was that in every other rule the teams are directly prevented from profiting from an illegal activity- with (this one) exception. You're right- it sounds like a loop hole. Kim- Wrong match. This one occurred during autonomous within seconds of 'go'- I think you are referring to one of the elimination bracket rounds... ? I loved being there and thought everyone was incredibly accommodating in an ever widening set of problems. Inspectors caught problems and provided help with solutions. Volunteers found answers to tough problems. In the end even the most contentious point I had was played as a rematch. |
#8
#9
I had a similar question about the official start of the match after DC. We also had a false start match. I asked around and it turned out in DC they were actually syncing Blair's (MC) "3-2-1-GO" with the start of the match. Thus Blair's "3-2-1-GO" was the de facto official start of the match. Actually tone is not really "official" or synced either. Remember in previous years drivers had to go by the clock not the tone when stepping forward after auto. Since you have to wait a second to figure out if the clock is running it is a very poor indicator. Probably the best indicator (and most fair to the robots and auto programmers) is the lights on the alliance station wall. They go solid when the robots are enabled at the start of of the match. Of course blinking vs. solid is not a very clear indicator to humans. Anyways, as long as they pick an indicator and are consistent about it is not a problem. |
#10
Sorry for going off on a little tangent there, but the replay was definitely the right thing to do in the case of a field fault. I don't want to start another thread or get yelled at for hijacking this one, but did anyone have experiences as ridiculous as the ones that went on in Portland in terms of the FMS and field errors described in that fourth point? |
#11
I've always told teams to watch the clock for the end of autonomous and to not depend on audio cues. Wetzel |
#12
I agree that overall that FLR went very smoothly. However, I would like to add another one to the mix here.
6. During a match, we were on the blue alliance. One referee on the red alliance's side of the field waved a red flag about a minute into the match and pointed to the red human player within the red alliance station. The waving of the red flag and pointing to red human player were very clear. This same event happened again about twenty seconds later, indicating a second penalty on the same person. No blue flags waved for the match to indicate penalties on the blue alliance. The final score of the match was 60-60 before penalties. The blue alliance members were all fairly certain that the worst case scenario was that these red penalties were overturned and it would be a tie. However, not only were those penalties overturned to give the red alliance zero points in penalties, but the blue alliance was given 40 points in penalties. After the match, the explanation was simple. The referee who made the call against the red alliance "did not know the rule" regarding whatever he had given a penalty for. That's fine. Everyone is human. Live and learn. The 40 points in penalties assessed to blue, however, were all for the same thing. Our human player apparently reached his hand over the alliance station wall. He does not jump when he shoots. Human players out there know how truly tough it would be to stick their hand over the wall without becoming airborne because of the airlock right in front of them. Not only were these points given, any logic of "he cannot reach that far" was not looked into. We were told that because no other referee could overturn the call, it would stand. That's right... 4 penalties for the same thing without a flag being waved for something that was physically impossible for our human player. Some people also saw video evidence later in the day where it apparently "was not even close to a penalty". The worst part was that a referee was then standing right there the rest of the day to watch our human player. I don't care who you are, it is harder to perform well when someone is watching you the entire time. So I thought I would share that as personal venting for the regional. Also, we were one of the teams which won the match you talked about in point 4. The teams were all very gracious and when you look at it from their point of view, it really is the only fair call. I am glad that it was replayed because that would be a horrible way for them to have lost a match. |
| Rochester Off Season Event | andyhoyt911 | General Forum | 3 | 21-08-2007 16:27 |
| paper: 2006 IRI Rules Changes and Clarifications | Andy Baker | Extra Discussion | 1 | 23-07-2006 02:47 |
| Rochester Area Pre-Ship Event? | Yan Wang | Off-Season Events | 3 | 11-02-2005 17:55 |
| Womens' Tournament Rules Changes | Mr. Mac | OCCRA | 7 | 01-12-2002 04:24 |
| Mid-Atlantic Regional | archiver | 2001 | 5 | 24-06-2002 01:46 |
