Go to Post Drive fast...drive true...otherwise it will kind of crush you - techhelpbb [more]
Unread 08-03-2009, 22:17
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
How do I add a VI?
A team gave us a VI they use to limit the joystick values. They say it has helped a great deal with traction control. We have the joystick limit VI file but what do we do to get it to work with the rest of our program? Thanks in advance.
Unread 08-03-2009, 22:24
Re: How do I add a VI?
Move or copy it to the same directory as the rest of your source. Then open the diagram where you want to call the subVI. Drag the subVI from the explorer window to the diagram. Hook up the wires and test.
Greg McKaskle
How can you add more rom space to the cRIO? Comatose FRC Control System 8 05-02-2009 21:16
HOW-TO Add an Addtional IR Reciever to FIRST IR Board The Lucas Sensors 2 18-02-2008 22:28
How do we add WPILib files in prog??? ambie_o7 Programming 5 20-02-2007 01:35
How can we add color to etched aluminum??? archiver 2001 1 24-06-2002 01:02
