Go to Post Nerds do whatever they want to do, and they do it with style. - EricVanWyk [more]
Unread 06-02-2009, 14:04
koka230 koka230 is offline
AKA: Scooter
FRC #0388 (Maximum Oz)
koka230 is an unknown quantity at this point
Send a message via MSN to koka230
robot dimensions
i know this is a dumb question the rules say that the robot must not exceed the dimensions when starting but what about after the match starts i find the rules a little contradicting
Unread 06-02-2009, 14:07
bmarick bmarick is offline
FRC #2374 (Crusader Bots)
bmarick is on a distinguished road
Re: robot dimensions
you can not leave the robot contraints during the match either
<R11>
Unread 06-02-2009, 14:08
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
The rules mean that at any time during the match your robot may not exceed the dimensions of 28x38x60. Just imagine that your robot has to fit within a box with those dimensions for the duration of the match.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 06-02-2009, 14:09
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Check out <R16>. To paraphrase, your robot can change its configuration as long as it doesn't exceed 28X38X60 or the bumper perimeter, whichever is the most restrictive.
Hi!
Unread 06-02-2009, 14:17
AKA: Scooter
if the robots dimensions are 18 by 28 on the bottom (where the wheels are)per say at the top of the robot is 28 x 38 does the top of the robot have to have bumpers
Unread 06-02-2009, 14:23
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
This is not possible. The BUMPER PERIMETER is determined at a height of between 1" and 7" above the floor and, as nothing maybe extend beyond the vertical projection of that BUMPER PERIMETER, it's impossible for a legal robot to be wider at its top than at its bottom.
--Madison--
...down at the Ozdust!
Unread 06-02-2009, 14:25
dtengineering's Avatar
AKA: Jason Brett
The bumper perimeter is established by wrapping a string around the robot's maximum dimensions within the bumper zone, which is defined as between 1" and 7" off the floor.
If you extrude the perimeter defined by that string vertically to a height of 60" off the floor then the entire robot must fit within the resulting shape.
So if any part of your robot, at any height, is 27x37, for instance, then the bumper perimeter MUST be at least 27x37. The situation you describe, with a 18x28 bottom and 28x38 top would be in violation of the rules as the top part of the robot would exceed the bumper perimeter.
This is to ensure that during interactions between robots and the playing field that the first thing to make contact is always the bumper.
Jason
Unread 06-02-2009, 14:28
Madison's Avatar
FRC #0488 (Xbot)
what rule says that
<R16> Once the MATCH has started, the ROBOT may assume a PLAYING CONFIGURATION that is different from the STARTING CONFIGURATION. The ROBOT must be designed such that the PLAYING CONFIGURATION of the ROBOT shall not exceed the dimensions specified in Rule <R11>. When in the PLAYING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the BUMPER PERIMETER.
BUMPER ZONE – the volume contained between two virtual horizontal planes, one inch above the
floor and seven inches above the floor.
--Madison--
Unread 06-02-2009, 14:33
AKA: Scooter
what rule says that
where is the rule getting to the bumpers must 1 - 7 inches off the floor
Last edited by Madison : 06-02-2009 at 14:35. Reason: Questions answered above, posts merged.
Unread 06-02-2009, 20:00
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Page 4 of the Section 8 "the Robot" defines:
BUMPER ZONE – the volume contained between two virtual horizontal planes, one inch above the floor and seven inches above the floor.
And then R08 "P" states:
P. BUMPERS must be mounted to the ROBOT within the BUMPER ZONE, and must remain there. The BUMPERS must not be articulated or designed to move outside of the BUMPER ZONE.
Unread 06-02-2009, 20:03
AKA: Scooter
thanks you guys for clarifying this for us and good luck to everyone
Unread 08-03-2009, 12:25
rjmah rjmah is offline
rjmah will become famous soon enough
OK we and a few other teams got <R11> infractions at Finger Lakes. I only wish that inspectors had checked our mechanism operation during the power up check. Now I notice it is only in the cursory visual inspection list on the inspection sheet. Given this unique constraint this year, I believe it warrants checking with power on.
Robert Mah
Team 1246 Agincourt Lancers
Unread 08-03-2009, 18:23
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Sorry for your penalty, however, if you read the bottom of the inspection checklist( http://www.usfirst.org/uploadedFiles...%20Rev%20D.pdf) the team captain and mentor certify that the robot is built to the rules.
We, the Team Mentor and Team Captain, attest by our signing below, that our team’s robot was built after the 2009 Kickoff on January 3, 2009 and in accordance with all of the 2009 FRC rules, including all Fabrication Schedule rules. We have conducted our own inspection and determined that our robot satisfies all of the 2009 FRC rules for robot design.
Unread 08-03-2009, 22:19
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Wait, infractions as in plural? You mean you got multiple penalties for it? Why didn't you fix it after the first one? Some of the rules seem obscure and easy to overlook, but that one seems to be one of the main rules of this years game. I just don't see how multiple teams at a regional overlooked it. Sorry, I know overlooking a rule is annoying. I've had related problems my rookie year(completely missed the motor restrictions). But, this is always just a reminder to read the manual more carefully next year.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 08-03-2009, 22:27
Robert,
What exactly does your robot change from starting config that caused the violation?
Robot Dimensions UBY General Forum 3 11-02-2008 04:38
Robot Dimensions nzamorski Technical Discussion 3 09-01-2008 21:39
Average Robot Dimensions TJ4nier Rules/Strategy 1 17-01-2007 15:00
hmmm possible robot dimensions? amos229 Rumor Mill 7 04-01-2007 12:29
Dimensions of robot box lampson0 Robotics Education and Curriculum 8 17-12-2006 12:35
