Go to Post No FIRST event is complete without Darude's Sandstorm. - sonichammer7476 [more]
Unread 09-03-2009, 00:57
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
pic: FRC-34 2009 Swerve Module w/FP (Side View)
Unread 09-03-2009, 00:58
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: FRC-34 2009 Swerve Module w/FP (Side View)
Very Clean Ed, very impressed. Looks amazing. Any specs the gearbox and how heavy is with and without a cim.
R.C.
MadTown Robotics Team 1323
Unread 09-03-2009, 01:00
I LOVE seeing 34's drivetrains each year. You guys never disappoint.
Unread 09-03-2009, 02:02
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
WOW. diggin the detailed shots! this is really clean and well thought out! These do look similar to the 111 swerve that works so well. do your delrin plates simply sandwich the bottom circle? if so, what does that little block on the edge do?
although it looks machining heavy, i can see the benefit of the weld less chassis, no doubt what that repeated hole pattern is for.
good work
*edit: OH MY, there are so many andy-mark parts here! the sprocket, the gears, the axle, the encoder, the bearings. wow!
**edit: OH MY, and your coming to Lone Star, OH BOY!!!
Unread 09-03-2009, 13:42
There's also two AM 500 Hubs and two of the short hex shafts. The little block on the bottom prevents an "Out of control" module from spinning more than 320 or so degrees. It interferes with another plate on the bottom bearing (not shown). I'll post an exploded view of the whole thing after we get back from Peachtree.
Ed Sparks
MECH TECH FRC-3959
Unread 09-03-2009, 13:48
The CIM version weighs 7.4 lbs. The CIM itself weighs 2.9 lbs.
The FP version weighs 6.0 lbs. The FP/Planetary weighs 1.5 lbs.
- so -
The module without motor weighs 4.5 lbs.
Note: If you look close, I cheesed the gears and the small hex shafts to get about half of the steel weight out (saved about 0.5 lbs per module).
Ed Sparks
MECH TECH FRC-3959
Unread 09-03-2009, 14:02
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Ed,
Very nice! Kudos on an elegant design.
Good luck to 34!
-John
pic: 1346 Side View 2009 dtengineering Extra Discussion 8 05-02-2009 15:23
pic: FRC 1771 Swerve Module sdcantrell56 Extra Discussion 17 13-04-2008 00:36
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
