Go to Post Defense shall reign supreme. - Corey Balint [more]
Unread 09-03-2009, 14:41
Richard.Varone's Avatar
Richard.Varone Richard.Varone is offline
AKA: Rich Jr.
FRC #0271 (Mechanical Marauders)
Richard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really nice
Send a message via MSN to Richard.Varone
Re: Dead DS ethernet ports? Post here!
We are also having problems with both of our ethernet ports, what happens is you plug the ethernet into either port and power on the DS, and you get no communitation ( the LED doesn't light up ).
A fix for us is once powered on and booted up, switch the cable to the other port while the DS is still on, and then power cycle, this seems to work for us every time.
Like I said this works for us, but i guess its worth a try.
Unread 09-03-2009, 14:47
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Originally Posted by domoarigato View Post
We had a bit of an oddity...
When in the pits, tethered to our robot, the both Ethernet ports on drivers station would work. However, every time that we went to a match, the drivers station's Ethernet ports would not work with the arena. We used the spare and that worked with our robot in the arena.
...Then we would go back to the pit and it would work again with the tether! AGHHHHH!
We had 2 Texas Instruments employees look at our problem and none of them could figure anything out.
This happened to us at NYC. The problem was we did not have the driver station at the latest release. Worked tethered but not on the field. Problem resolved before matches began.
Unread 10-03-2009, 21:03
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
At DC Regional we lost port 2 on one DS and port 1 on our spare DS. Link light would continue to flash in appropriate manner on port 2 of first DS, but DS could not be pinged from PC when connected to PC via port 2. Second DS failure link light would stay on even when cable was removed. Using an ethernet switch allowed us to continue to program the robot with a single port failure. Wire DS to switch through good port, PC to switch, and cRIO to switch.
Before the first DS failed completely, we had been having difficulty staying connected in debug mode.
Several other teams lost one port. One team lost both. DS does not appear to be robustly designed. I have heard of no cRIO network port failures or PC network port failures, only the DS seems to be susceptible.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
DS Ethernet ports coming loose phobeste FRC Control System 1 02-02-2009 21:35
Post your robot here R.C. General Forum 2 19-02-2008 19:06
Rookie teams post numbers here! Older teams look for teams to mentor here! Erodge General Forum 1 07-10-2002 13:40
POST YOUR BIRTHDAY HERE. archiver 2000 24 23-06-2002 23:04
What is IT??? - Post Ideas Here Tom Schindler Dean Kamen's Inventions 20 02-12-2001 02:32
