Re: Pressure Switch Problem?
One common mistake is to wire it between the 5V and 0V rails on the digital side car. This will short out that power supply, which will put it into a safety shutdown and cut all signals to your motor controllers.
Instead, you should wire it between signal and 0V. A resistor built into the digital sidecar will give it the "power" it needs. |
| Pressure Switch | R.C. | Pneumatics | 3 | 24-04-2008 01:54 |
| pressure switch | M.Jesus | Pneumatics | 1 | 15-02-2008 17:36 |
| [OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. | BrittanyV | OCCRA | 3 | 16-10-2006 15:42 |
| pressure switch | Michael Long | Pneumatics | 1 | 11-02-2003 11:21 |
| pressure switch | piconysm | Technical Discussion | 5 | 14-02-2002 23:15 |
