Go to Post There's the problem!! The #1 reason to blame the programmers: They always forget to grease their code. :rolleyes: - Jack Jones [more]
Unread 09-03-2009, 17:29
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
Mini Chain
Any of you out there that use "mini chain", where do you get it and where do you get sprockets for it?
Thanks
Matt
Team 894 Chargers Robotics
Unread 09-03-2009, 17:33
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Re: Mini Chain
I'm assuming by mini-chain you mean ANSI 25 chain? This is the small type chain that many people use on robots.
You can get sprockets at McMaster-Carr
Just search for "Chain Sprockets"
Then click "ANSI 25" on the main page.
I don't know if a link will work?
http://www.mcmaster.com/#chain-sprockets/=xjmyx
Unread 09-03-2009, 17:39
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Re: Mini Chain
Andy Mark sells aluminum 25 ansi sprockets.
http://andymark.biz/25sealsp.html
Mens et Manus
Unread 09-03-2009, 18:22
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Mini Chain
McMaster sells everything you need.
http://www.mcmaster.com/#ansi-25-roller-chain/=xk9uf
And AM and IFI sell aluminum sprockets.
Unread 09-03-2009, 18:29
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Mini Chain
SDP/SI sells 0.1475 in/3.75 mm pitch chain that seems to be roughly similar in design to ANSI B29.1 #25 chain, but smaller. (Search their catalogue for part numbers beginning with A 6Y 7-M or A 6Y 7MM.) Sprockets are available as well.
They also sell snap-together plastic chains in 0.1227 in/3.117 mm pitch (A 6M 7-12 or A 6M 7M12), and matching sprockets.
And of course, if you want #25 or #35 chain, they have that too, in steel, stainless steel, nylatron, acetal, or polypropylene, with metal or plastic sprockets to match.
If you're not so interested in power transmission, they also have various kinds of ladder chain.
Unread 09-03-2009, 19:01
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: Mini Chain
Not exactly what you're looking for, but if you were in Brazil, you'd only be able to buy #25 chain and links. Sprockets are virtually non-existent.
Fascinating, isn't it?
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Chain cz2062 Inventor 20 03-02-2009 16:57
Chain hong12891 Inventor 8 05-02-2007 20:03
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
