Re: Timing belt size
The CIM motors have an 8mm shaft. 8mm is also very close to 5/16" if that helps.
| Splice Timing Belt | comphappy | Technical Discussion | 4 | 07-02-2009 09:37 |
| timing belt ordering | XXShadowXX | Technical Discussion | 3 | 26-01-2008 17:01 |
| Timing Belt Clamp | shorton | Technical Discussion | 10 | 18-07-2006 22:50 |
| two sided timing belt | archiver | 2001 | 3 | 23-06-2002 22:34 |
| Timing Belt Recommendations? | Eric Reed | Technical Discussion | 1 | 10-01-2002 00:25 |
