Go to Post I know you've finished the first 75% of the robot, but do you have enough time left to finish the other 75%? - Rick TYler [more]
Unread 09-03-2009, 20:44
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
Round belting
Well, as I sit here ready to submit our order to McMaster-Carr, I am wondering if we should get some different round belting. We have the clear belting right now, but we are having problems with it stretching and popping off. The other option on the website is yellow belting, and I was curious is there is a difference in the elasticity and also the 'grip' of the belt.
Thanks one again, you guys are so helpful and have made our first year a successful learning experience
Unread 09-03-2009, 20:49
Billfred's Avatar
Billfred Billfred is offline
Re: Round belting
2815 used clear belting this year (as seen in my WAI). On occasion, it does pop out of its groove on our rollers--but we've got six such belts on each segment, so it's something we can survive until we get the robot back to the pits. The net result is a rock-solid system.
Can you describe your system, or give us pictures to show where things are going awry? (I wouldn't wish having to weld a bajillion more belts on anyone...I think I'm just now getting over the fumes.)
Unread 09-03-2009, 20:54
Bob Steele's Avatar
AKA: Bob Steele
Re: Round belting
How much are you stretching the round belting before you put it on?
You should measure you size and take off at least 7-10% of that length and join the tubing. Then stretch it on...
We are using it and haven't had any problems with it falling off..
We did run it for awhile and then took off an additional 4 inches from each belt before we shipped.... our belts are something around 9-12 feet long...so this was an additional 2% in addition to the original stretch.
We use the orange belting which is pretty much identical to the clear.
Unread 11-03-2009, 13:09
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Re: Round belting
We had some good luck with the orange material.
We got ours from Grainger - they offered to import more for us from India... I think it was going to be 20$/50ft (pretty cheap)... but I can try and find the exact quote for you.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 11-03-2009, 20:37
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Round belting
what size belt and roller are you using? there are some recommended minimum sized rollers for different diameters of belting.
we are using 4 different sizes of the 3/16" clear from McMaster-Carr
- about 24", 30", 74" and 84", running on 1-1/2" diameter PVR rollers.
each size is aout 8% smaller than the actual measurement and so far they have not jumped the grooves.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
fitting a round rod in a round hole GMKlenklen CAD 12 23-08-2009 01:20
Round Belting - Solid vs. Hollow, Polycord vs. McMaster dtengineering Technical Discussion 58 31-01-2009 12:15
Which belting? lukevanoort Technical Discussion 1 21-01-2006 16:03
pic: Swing yer parders round n' round! Koko Ed Extra Discussion 8 26-05-2005 13:07
Belting snowdragon Kit & Additional Hardware 4 16-01-2004 09:00
