Go to Post You can build an amazing robot that is capable and beautiful on a limited budget. - Andy Baker [more]
Unread 09-03-2009, 23:47
stuartd stuartd is offline
FRC #0118
stuartd is an unknown quantity at this point
Using more than 4 encoders
Our team is having trouble using more than 4 quadrature encoders at one time. If we only use 4 or less, everything functions perfectly. When the 5th encoder is added in to the mix strange things begin to happen. The first allocated encoder stops working and the 5th encoder movement appears for both the 5th and 1st encoder.
At first we thought this was a function of our competition code (we use another level of abstraction with the encoders). We then reproduced problem in a SimpleRobot project (see attached). Are we just making a really stupid mistake or can someone verify this issue?
Unread 09-03-2009, 23:50
Re: Using more than 4 encoders
See http://forums.usfirst.org/showthread.php?t=10821
Unread 09-03-2009, 23:57
In brief, there are only four "4x" encoders in the hardware. Selecting "1x" or "2x" encoders uses hardware counters instead.
Unread 10-03-2009, 00:47
FRC #0118
Well that makes perfect sense... should have looked deeper in to the hardware behind reading the encoders. I'll drop one of the encoders down to 2x and see if that helps tomorrow. Thanks!
CRio more than nationals lenny8 FRC Control System 6 16-11-2008 12:33
More than One Regional? smurfgirl Regional Competitions 35 26-03-2008 14:21
More than 1 autonomos... Jimmy_Team7011 Programming 5 16-03-2008 15:33
more than 4 ir controls? Vanquish Programming 2 12-01-2008 14:52
More than 2 pneumatic tanks? kangarue23 Pneumatics 10 01-05-2002 12:14
