Go to Post While you look at it as punishment, I look at it as a challenge. - Daniel_LaFleur [more]
Unread 10-03-2009, 11:43
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
Re: Pinning Long Robots
we have found a trick that works for our robot, if you notice our robot has between 75% and 80% of its weight on the back two wheels, this essentially makes us a wide robot. (we are narrow) when we are hit the front of the robot pivots into the turn, which rotates the robot in a circle, pulling the trailer away from the pining robot. we can increase our turn by utilizing our turret. our robots turret is a large part of the robots weight, and by accelerating it we turn. (35lb turret with a 27.5" diameter provides a lot of rotational inertia) we designed our turret to act like a gyroscope.
295 Team Captain
Unread 10-03-2009, 18:45
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
After attending both the NJ and NYC regionals, and driving 25 matches between them, i found the best way to not get pinned is to drive backwards. Our robot was in the long configuration, and since the trailer is about the same width as our robot, i never had a problem getting out of getting pinned. Driving backwards lets you turn way easier, as the trailer helps spin you around. Another great way to not get pinned is to have a robot on your alliance pin the other alliances robots (thank you team 1796).
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
Unread 10-03-2009, 21:01
Spyder Tom 1622's Avatar
Spyder Tom 1622 Spyder Tom 1622 is offline
AKA: Tom Chenier
FRC #1622 (Team Spyder)
Team Role: Human Player
Spyder Tom 1622 is an unknown quantity at this point
Exclamation Re: Pinning Long Robots
[quote=pacoliketaco;834345] Our robot was in the long configuration, and since the trailer is about the same width as our robot, i never had a problem getting out of getting pinned. QUOTE]
Just wait til' Atlanta, you will see the amazing power of 2543 Titan bot. i do believe from all the matches ive seen, they are the powerhouse to watch out for.
Unread 10-03-2009, 21:22
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Do not assume that what you've seen is what you will get at Atlanta.
There are defensive bots out there that are just plain incredible.
___________________
- Tennyson, Ulysses
Unread 10-03-2009, 23:15
JSmith397's Avatar
JSmith397 JSmith397 is offline
Jared Smith
FRC #0397 (KnightRiders)
JSmith397 is an unknown quantity at this point
as a long robot ifound it easy to pin and out manuvere wide robots backing up truly does help
Unread 11-03-2009, 00:07
HighLife's Avatar
HighLife HighLife is offline
FRC #0245 (Adambots)
HighLife will become famous soon enough
Send a message via AIM to HighLife
Originally Posted by Taylor View Post
Why not just drive backwards? The inertia of the defending bot will take it with you and turn it to its left, freeing you to do as you please.
Also this depends on your proximity to the wall. If the wall is directly to the left in this drawing, you're in a bit of hurt.
You got it, drive backwards and try to swing your robot around.
Here are the Kettering videos IKE was talking about: http://www.adambots.com/wiki/FIRST_2009_Videos
Watch our robot (The yellow power dumper). As the driver I used this little maneuver to get out of a lot of defense.
AdamBots.com- Winner of 7 Best Website Awards!
Best Pinning Robots You've Seen so Far Akash Rastogi Technical Discussion 22 03-03-2009 18:44
Is pinning opposing robots trailers allowed? spiffyspleen Rules/Strategy 22 05-01-2009 16:47
Pinning a Mechanism Rob2713g Technical Discussion 5 30-01-2008 13:11
Clarification on Pinning Stu Bloom Rules/Strategy 2 15-03-2006 05:07
Ramming/ Pinning f22flyboy General Forum 21 07-03-2003 20:39
