Go to Post Just be nice. It works better in the long run. - Libby K [more]
Unread 10-03-2009, 13:05
Hazmatt's Avatar
Hazmatt Hazmatt is offline
AKA: Matt
FRC #2645 (PowerSurge)
Hazmatt will become famous soon enoughHazmatt will become famous soon enough
Labview labels not showing up correctly
The labels in our labview program aren't showing up correctly. Every time we enter something it shows up as a bunch of squares instead of text. Labels from older programs still show up correctly though. Any help would be appreciated.
Relax! It's only ones and zeros!
Unread 10-03-2009, 13:23
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Labview labels not showing up correctly
Sounds like a font issue to me.
Russ
Unread 10-03-2009, 13:38
Dave75 Dave75 is offline
AKA: Dave Blackburn
FRC #0075 (RoboRaiders)
Dave75 is an unknown quantity at this point
Check the Font you have selected - in the toolbar (right under the Menu). It ought to say "13pt Application Font". If it does not, simply click the drop-down arrow next to it and pick "Application Font" (near the top).
Unread 10-03-2009, 17:08
Hazmatt's Avatar
AKA: Matt
thanks, worked perfectly.
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
[FTC]: Help requested, the NXT is not showing the battery as being connected. crazilyrandom1 FIRST Tech Challenge 2 17-01-2009 11:24
Michigan District Stuff not showing up in Portal Ken Patton CD Forum Support 8 07-08-2008 14:45
NASA/VCU is NOT scoring Hybrid Mode correctly!!! Racer26 Regional Competitions 13 07-03-2008 20:44
Pinion not machined correctly Coachmac Kit & Additional Hardware 2 14-01-2005 10:28
