Go to Post Mentoring is HARD. - Akash Rastogi [more]
Unread 10-03-2009, 18:47
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
CIM motor with AM planetary
Hi,
I was wondering is anyone has used a CIM motor with the AM planetary gearbox. I'm not referring to the to their new gearbox designed specifically for the CIM, but the one generally used with the Fisher Price. Their site says it can be used with a CIM with slight modifications, but doesn't describe the changes. If anyone has used the CIM with this gearbox, info would be greatly appreciated.
-Seth
Mens et Manus
Unread 10-03-2009, 20:21
AdamHeard's Avatar
Lead Mentor
Re: CIM motor with AM planetary
To do it cleanly it requires a bit of work, but the end product is very nice.
We pulled the shafts from the CIMs and cut them to length on the lathe.
Reamed the pinions for a press fit on a lathe as well and then pressed them flush with the end of the now shortened CIM shaft.
Assembly is a bit odd, as you must bolt the plate to the gearbox first, then go through the AM planetary's facemounting holes to attach bolts to the CIM.
This will all make much more sense once you try it.
In the end, it works great, and has been very reliable so far.
Unread 10-03-2009, 20:29
Ice Berg's Avatar
Seth Berg
AKA: Seth Berg
Thanks for the quick, detailed reply.
Is removing and then putting the CIM shaft back as tricky as it sounds? I plan to try this tomorrow. Do you have any tips on how not to ruin the motor, because this sounds like on of the few ways to mess up a CIM motor. Also how did you decide what length to cut the CIM shaft to?
Mens et Manus
Unread 10-03-2009, 20:37
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Woah woah woah woah woah, isn't that considered modifying the motors? That's a direct violation of rule R53:
The integral mechanical and electrical system of the motor is not to be modified.
I win! XD
Unread 10-03-2009, 20:48
Ice Berg's Avatar
Seth Berg
AKA: Seth Berg
Is there a way to use the gearbox without altering the shaft? Is altering the shaft forbidden by this rule? It does sound like it. If the shaft has to be cut down to use it with the gearbox then can it basically not be done?
Mens et Manus
Unread 10-03-2009, 20:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by <R53>
...except as follows:
A. The mounting brackets and/or output shaft/interface of the motors may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part.
Not quite a violation, if you don't take the motor apart.
If you do take it apart, but reassemble it, it's a more difficult call.
Unread 10-03-2009, 20:59
AdamHeard's Avatar
Lead Mentor
You could shorten the shaft via a hacksaw and then grinding the edges nice, we just chose to do it on a lathe for a nicer cut.
The motors were disassembled and reassembled by an engineer who knows motors, and they were reassembled into the same configuration. This purely modified the shaft, and is within the rules as I believe. This has been allowed in the past with the warning of, "be careful taking it apart, you could mess it up".
Unread 10-03-2009, 21:09
Don't make me...
Previous years' rules and rulings do not apply to this year.
Unread 10-03-2009, 21:19
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
[puts on Robot Inspector hat] If the motor has the same free speed and free current in both CW and CCW directions after you put it back together, and they are the same as they were before you took it apart (within the limits given on the CIM data sheet), then you didn't modify it.
Did you measure the free speed and free current, CW and CCW, before and after? Are they still within CIM specs?
The best way to remove doubt is to show data.
Richard Wallace
since 2003
Unread 10-03-2009, 21:35
AdamHeard's Avatar
Lead Mentor
Don't make me...
I wasn't quote a previous year's rule, I was quoting intent that was stated about previous rules that are still written the same way.
It meets the rules. Period. I don't see anywhere it say you can't ever open motors as long as you don't modify them.
Unread 10-03-2009, 21:39
I know you weren't. However, you were referring to a ruling made on a previous year's rules. Hence my comment on rulings as well as rules.
Unread 10-03-2009, 21:48
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Whenever you take something apart and put it back together it will always be a little different.
The rule does not say functionally the same, it says modify.
Thus I suggest Q&A ... and I'll almost be willing to bet they'd say that a motor that was disassembled and then reassembled will be considered modified.
___________________
- Tennyson, Ulysses
Unread 10-03-2009, 21:57
Your reasoning is sound, but I'd like to point out that FIRST feels that disassembling a custom assembly into COTS parts is (generally) sufficient to restore their COTS status (i.e. they are considered "unmodified"). Does that process work in reverse?
Unread 10-03-2009, 22:14
Mad Scientist
AKA: Me
FRC #2040 (DERT)
This point is exactly why I said Q&A.
By strict definition it would be 'modified' even though it would still be functionally the same (and probably contain as much variation as an origonal from the factory).
I would still bet on the Q&A saying it would break <R53>.
___________________
- Tennyson, Ulysses
Unread 11-03-2009, 15:56
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Any quality component or assembly, when disassembled and reassembled by a competent person, should function nearly the same as new. Any performance differences would be negligible, and would be apparent across all of the unmodified parts or assemblies of its kind. I don't see how taking something apart is "modifying" it in any sense of the word.
Edit: In all honesty though, I think removing the shaft is overkill. A dremel cutoff wheel works just fine and does no damage to the motor or the remaining shaft if you are cautious to avoid excessive temperatures when cutting.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Cim/planetary gearbox torque?? Bruceb Motors 3 08-02-2008 11:01
AndyMark CIM Planetary Gearbox Torque Specs Needed KTorak Technical Discussion 4 17-01-2008 18:53
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
dewalt motor VS. CIM motor John Gutmann Motors 12 10-01-2007 18:57
Large Cim Motor? Fishdude404 Motors 1 27-01-2006 22:36
