Go to Post What's the reason for having a rule if it's not enforced? - jpsaul7usa [more]
Unread 24-06-2002, 02:43
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Code cycles per second
Posted by Matt Leese at 03/24/2001 9:38 PM EST
Other on team #73, Tigerbolt, from Edison Technical HS and Alstom & Fiber Technologies & RIT.
In Reply to: Re: Code cycles per second
Posted by Joe Ross on 03/24/2001 3:48 PM EST:
Ok, to further explain what Joe said:
A packet is sent from the OI to the RC 40 times every second. Your program, however, is not guaranteed to get every packet. This is because of the tri-microcontroller design of the RC. The Master Processor reads the data from the radio modem, the analog inputs, and the digital inputs. The Master Processor then passes it on to the BS2X (I believe all three microcontrollers are BS2X but the InnovationFIRST labels the user programmable one the BS2X). The BS2X reads the data at the beginning of a loop. The BS2X will block (meaning wait) until data is available. The variable packet_num will tell you which packet number you are on. This number does wrap around so beware. There also is a variable deltav that tells you how many packets you've missed. Therefore you can get a somewhat accurate measure of how much time has passed between loops. This should be accurate to .0225 seconds but I wouldn't count on that level accuracy.
Matt
[IMG] code is Off
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Autonomous Code From Experience EbonySeraphim Programming 7 14-03-2003 21:56
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
