Go to Post Liberal arts majors learning more STEM concepts along with STEM majors learning more 'liberal arts' is a good idea. - ebarker [more]
Unread 11-03-2009, 17:09
Killraine Killraine is offline
Team Robot
AKA: Josh Lucas
FRC #2016 (Mighty Monkey Wrenches)
Killraine will become famous soon enoughKillraine will become famous soon enough
Re: Unofficial animation entry reviews
Originally Posted by wsansewjs View Post
Make sure you read all of the posts in this thread before you posted yours because what you said has nothing to do with the discussion of the Autodesk animation entries, not the camera shots at the regional matches. LOL
-Josh S.
Oh I did read the posts, I didn't realize there was such a strict "No deviation" policy. I'll make sure to stay on topic in the future.
Unread 12-03-2009, 06:49
KHall KHall is offline
KHall - 2171 Crown Point IN
FRC #2171 (RoboDogs)
KHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud of
What is the link to access the animations on firstbase? Would like to view a couple to see what other teams have done. Thanks
Unread 12-03-2009, 13:57
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Click here to see the videos.
Unread 12-03-2009, 14:27
KevinReid's Avatar
KevinReid KevinReid is offline
FRC #2609 (Beaver worX)
KevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to beholdKevinReid is a splendid one to behold
Team 2609 would like feedback for our student animators, if you have the time.
Waterloo competition.
Unread 20-03-2009, 22:35
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Team 2609: Man-Made Beaver Dam
	+nice character---normally I suggest that rookie animators avoid characters altogether---while your character was not realistic, it served its job and was not distracting
	-again, split up your animation into multiple cuts.  watch a couple commercials on television and note all every camera change including how often they occur and what type of camera movement is in it.
	-narration has odd pauses in it, as if it was artifically expanded
	-the narration extends past the thirty-second time limit
	-the water sound was too loud relative to the narration.  bump the water sound down and the narration up.
	-the next topic your animators should consider learning is lighting.  Your animation this year had no lighting/shadows, but you have all of this year to figure that out, and I expect to see that in your animation for next year.
	-there is a way to get the fake flowing water to flow in a curve.  If you create a prim (e.g. plane or box) with many segments and make sure to have the mapping automatically mapped, and THEN bend the shape, the texture will keep the old texture coordinates and thus follow the shape.
	-consider putting a bit of splash/foam effect (white particles) around where the water hits the dam or bank to make the water even more realistic, but keep it subtle
	-same with the smoke
Essentially, your animators did a solid job.  The concept, while vague, worked.  More importantly, the way the idea was presented was clear and concise.  Keep it that way; don't fall in to the trap of animations that leave the watcher scratching their head or have distracting mistakes or shortcomings.  Keep your plans within the range of your abilities and focus on communicating your message.
I don't think I'll do any more evals unless they're requested. It's late in the season and I simply don't have the time.
Unread 21-03-2009, 00:41
boehmz boehmz is offline
FRC #1730
boehmz is on a distinguished road
Could you review 1730's animation? It's at the Greater Kansas City Regional.
animation entry question Tazlikesrobots 3D Animation and Competition 4 28-12-2005 10:18
Team 45-Animation Entry CADman 3D Animation and Competition 1 26-02-2005 00:55
Team 116 Animation Entry SteveC116 3D Animation and Competition 41 09-03-2003 21:53
TechnoKat Animation Entry.... Clark Gilbert 3D Animation and Competition 4 10-04-2002 07:23
Team Hammond animation entry Kevin Kolodziej 3D Animation and Competition 1 08-04-2002 21:00
