Go to Post The thing about working hard, is you can always work harder. The thing about being great is you can always be greater. - JVN [more]
View Poll Results: Was this useful?
Yes, it was! It helped point out diamonds in the rough 109 70.32%
No, its numbers generally did not correspond to robot's actual on-field performance 46 29.68%
Voters: 155. You may not vote on this poll
Thread Tools Rating: Thread Rating: 32 votes, 4.88 average. Display Modes
Unread 12-03-2009, 10:34
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Re: Easy to use Offensive Power Rankings (OPR) program for mid-regional scouting
Originally Posted by Bongle View Post
Steve's idea appears to be the same as mine, or at least his two equations are. I tried to implement it on tuesday, but it had bugs and I haven't had to time to get back to it. It is unfortunate that the matrix comes out as somewhat ill-conditioned, but I guess that isn't that terribly surprising since the amount of data we're processing is fairly small.
I'll try again to implement this new matrix tonight, and I'll plug it into my prediction code to see if it is any better than the more basic OPR/DPR stats.
We need to come up with a name for this more-complex stat: how about OPR+ and DPR+?
One other thing, then I'll go back to my day job ... When I was talking to Kenneth Massey (the BCS guy) he also suggested something, that would modify these equations just a bit - but would require team by team scouting. The red or blue score would NOT be the final score as published, but would first, obviously, not include penalties - so we are really measuring "capabilities" not just performance; and secondly, if you were to have added MR to your own alliance - so as to avoid <G22>, the points that you scored on a alliance partner would be removed from the opposing alliance's score. How much of an effect would this cause in the long run, I don't think much - but if we are basing the OPR+ and DPR+ on a limited number of matches, then it could very likely be significant.
Steve
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Offensive Power Ranking Calculations Greg Marra General Forum 4 18-03-2009 22:03
Offensive Power Rankings for 2008 Bongle General Forum 166 18-05-2008 15:05
Offensive+Defensive Power Rankings BornaE General Forum 4 05-04-2008 01:33
2006 Offensive Power Ratings sw293 General Forum 16 10-05-2006 17:04
(CURIE) Let's make this Easy for all of us. [scouting] 157#1Driver Championship Event 13 22-04-2002 08:56
