Go to Post FIRST is not about building robots, it is about building people; the robots are just a good way to get the people there. - JamesBrown [more]
  #31   Spotlight this post!
Unread 05-03-2009, 12:59
Re: Intresting Autonomous
Originally Posted by The Lucas View Post
Originally Posted by Alan Anderson View Post
One of our neighbor teams is using a ten-turn pot with a fancy readout on their Driver Station as a mode selector.
Cool idea, was that 007 or 53? I've only started to play with the DS display. I dont think I would ever switch to a scheme that required feedback from the cRIO.
It's Team 1760. They're our physical neighbor in the same county, not a numeric one.
They weren't using the DS display when I saw their system. The "fancy readout" is a very nice knob with special gearing and a mechanical attachment to the shaft. They're common in applications using ten-turn pots. Here's one such device: http://parts.digikey.com/1/parts/746...-011-1-11.html
  #32   Spotlight this post!
Unread 05-03-2009, 13:05
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Interesting Autonomous
If anyone gets a chance to watch the NYC Regional webcast (Saturday & Sunday), check out our auto-mode.
We're very proud of it, & it's completely intergrated into the drive system of the robot using a gyro as an assist, & is very cool in my opinion, but I'll let you all decide.
Comments welcome if you see it btw!
Thanks!
  #33   Spotlight this post!
Unread 05-03-2009, 14:28
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
The values should never be zeroed if the DS is in Auto Disabled state even if it is the last run (how would the DS know that anyway?). I dont have LV installed on this computer and I haven't studied the advanced framework or your code (I stopped programing in LV before the advanced framework, but I do understand LV, especially dataflow programming). However what I think is happening there (based on what I am hearing) is the Auto Disable LV state runs once while the DS is in Auto Enable (reason for the zeroing) before transitioning to Auto Enable.
Yep, we're both describing the same behavior - in LV the framework calls the Disabled.vi one time (at least) when the "derived robot state" is "stop", and at that point the DS inputs are read as zero. This is similar to that IterativeRobot race condition in C++.
I haven't looked at the DS packets to see whether the DS is actually reporting the state to be "enabed" or "disabled" when this happens, but we plan to check into it - it's a fun way to teach the kids about comm protocols and network analysis.
[EDIT: For anyone interested, after a quick glance at the LV WPI library code, it seems clear that the DS is actually reporting the state as enabled, the framework just intentionally runs the disabled vi an extra time to allow for clean up. So not a "race condition" but something to be aware of in the framework. You'll see what I'm talking about in the "Get Competition Mode.vi" which the framework uses to figure out what mode to run]
Ron
Team 2607 - software mentor
  #34   Spotlight this post!
Unread 05-03-2009, 16:42
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
It seems to me that, owing to symmetry, there are only three starting positions, so that with six autonomy choices a robot could have two options for each starting position.
  #35   Spotlight this post!
Unread 06-03-2009, 21:29
raffi383 raffi383 is offline
Build Mentor
FRC #0201 (FEDS 201)
raffi383 is on a distinguished road
Originally Posted by scoutmasterlord View Post
http://s255.photobucket.com/albums/h...City%20Videos/
this is a lot of team #201 matches.
scoutmasterlord,
Thanks for posting the link to the 201 website. I have more videos to upload but converting them from 265Mb avi to smaller mpeg is taking a while.
I also want to thank TVan from team 85 for admitting that they did not invent "auto-spin".
I can't say that we invented it either but it was programmed in the robot when we got to Traverse City and we used it in every match.
I haven't counted how many balls landed in the trailer during autonomous but it wasn't very many.
I especially like the video of Qualifying Match 38 where 85 and 201 were doing synchronized spinning.
It seemed like more and more teams used auto-spin as the weekend went on.
By the time we get to the Detroit regional, there will probably be six spinning robots in each match.
Raffi
  #36   Spotlight this post!
Unread 06-03-2009, 21:45
Build Mentor
I had to do it. I watched all the videos to see how many times we were scored on in autonomous.
I don't have video of match 1 or 8 but I have the rest.
I counted all the balls that landed in the trailer from the start until the buzzer at the end of autonomous when the robot stops spinning.
Here they are listed by match number and ball count:
18: 0
21: 0
27: 0
38: 0
43: 2 we got trapped
47: 0
55: 0
59: 0
68: 0
72: 0
Qtr 4-1: 0
Qtr 4-2: 0
Semi 2-1: 0
Semi 2-2: 1
Semi 2-3: 2, one was scored by our own alliance member
Raffi
  #37   Spotlight this post!
Unread 06-03-2009, 21:53
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
18: 0
21: 0
27: 0
38: 0
47: 0
55: 0
59: 0
68: 0
72: 0
Qtr 4-1: 0
Qtr 4-2: 0
Semi 2-1: 0
Semi 2-2: 1
Raffi
I can tell you that in match #1 that we didn't get a single ball scored on us during auto. I was reviewing the crude video that I took, and I didn't see any balls go into it.
And for future reference try to edit your earlier post to include the extra info if no one has replied after you.
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
  #38   Spotlight this post!
Unread 12-03-2009, 12:03
scoutmasterlord's Avatar
scoutmasterlord scoutmasterlord is offline
AKA: John Lord
FRC #0001 (Juggernauts)
scoutmasterlord can only hope to improve
Send a message via AIM to scoutmasterlord Send a message via Yahoo to scoutmasterlord
if u can get my status in to the green
  #39   Spotlight this post!
Unread 12-03-2009, 16:08
Hazmatt's Avatar
Hazmatt Hazmatt is offline
AKA: Matt
FRC #2645 (PowerSurge)
Hazmatt will become famous soon enoughHazmatt will become famous soon enough
Originally Posted by Vikesrock View Post
Switches on the DS side can still be read and used to select Autonomous modes. The difference is that they now cannot be read in Autonomous/Enabled mode. Read them in Autonomous/Disabled and cache the values for use during Autonomous/Enabled. Also, there are reports that the values return incorrectly from the last cycle of Autonomous Disables, so make sure your code has a way of dealing with this.
Where exactly in the labview code should we read the analog inputs? Should we read them in the basic robot main vi under the "Other" section? Or is there somewhere in the autonomous independent code that we should put it? Thanks!
Relax! It's only ones and zeros!
  #40   Spotlight this post!
Unread 12-03-2009, 16:15
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire (on sabbatical))
Raffi
A lot of teams might incorporate that, but we will never use that - our autonomous has been pretty unique and is key to our strategy. I also don't see 70/494 spinning in auton.
  #41   Spotlight this post!
Unread 12-03-2009, 16:57
AKA: Ron R
It's not straightforward to do with the LV basic framework. Take a look at the example code (using the LV advanced framework) attached to this post:
http://www.chiefdelphi.com/forums/sh...2&postcount=26
It shows reading the digital inputs, but the same principle applies to the DS analog inputs as well.
Thanks,
Ron
  #42   Spotlight this post!
Unread 12-03-2009, 23:22
You can read them in the Basic Robot Main outside the big case block, and store their values in a control in Basic Robot Global. Read the Global in Autonomous Independent to decide what to do with it.
You will need to delay storing by one loop time, because the Main gets called one extra time after Autonomous is enabled, with all the analog inputs at zero. I'd use a feedback node to pass the value to the next iteration of the loop. I think the other alternative, a shift register, clutters up the block diagram more.
  #43   Spotlight this post!
Unread 12-03-2009, 23:43
rogerlsmith's Avatar
rogerlsmith rogerlsmith is offline
Software Engineer
AKA: Roger Smith
FRC #3357 (COMETS)
rogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to behold
Team 904 is scoring autonomously as this video begins. This is a match in week 1 at the Traverse City District event in Michigan. The rest of the match is primarily focused on our team.
Roger Smith
Mentor - FRC Team 3357
COMETS - Creating Outstanding Minds, Embracing Technology & Science
Share FIRST videos, photos and experiences at FIRSTObjective.org
  #44   Spotlight this post!
Unread 20-03-2009, 13:25
eschanz's Avatar
eschanz eschanz is offline
B.A.
AKA: Evan Schanz
FRC #1254 (Entropy)
Team Role: Human Player
eschanz is infamous around these partseschanz is infamous around these parts
Send a message via Yahoo to eschanz
Does anyone have a picture of 1254 if u do please post it. thanx
  #45   Spotlight this post!
Unread 05-04-2009, 12:27
Ryan_Todd's Avatar
Ryan_Todd Ryan_Todd is offline
ye of little faith
Ryan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond repute
My team has used two 6-position rotary switches to select our auto routines for the past few years. They give us 36 slots (usually enough even for our team) using only 2 analog ins as opposed to 5+ digital ins (usually need those for other controls).
My team has been searching for analog switches of the variety you speak of, but we haven't been able to locate anything that we were certain was what we were looking for. Could you please post a link to somewhere that we could purchase those switches? Thanks!
Autonomous Whitetail Freak Programming 5 14-02-2009 07:35
pic: I drove 173 miles after i filled up my gas tank! Hmm Intresting? R.J. Chit-Chat 10 07-01-2007 16:19
A intresting question Jeremy Chit-Chat 9 19-02-2004 12:48
R.A.G.E. Autonomous? DarkJedi613 Regional Competitions 7 17-03-2003 21:33
Intresting Article Kyle Fenton Chit-Chat 0 21-11-2001 17:02
