Go to Post I wonder if Radio Shacks all over should prepare for VEX robots dropping by for spare parts just like people going to a medical clinic... - Wayne C. [more]
  #31   Spotlight this post!
Unread 11-03-2009, 18:24
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: pic: 233 Pink Roccobot 2k9
That's a Nice Robot but the Pro-E Model is even nicer.
I showed that Model to my mentor at work and he was amazed that you were able to make something that nice in 2 weeks. How many people worked on it? I'm assuming that it was a group of people because that would be almost impossible to do with one person. (Then again, you are the PINK team.)
Back to the robot though, that is by far one of the most beautiful robot's I've ever seen. I'd love to see it function, something tells me I'd be very fun to watch the balls snake through that delivery system.
-Dustin Benedict
  #32   Spotlight this post!
Unread 11-03-2009, 19:26
amariealbrecht's Avatar
amariealbrecht amariealbrecht is offline
Alicia Albrecht
FRC #2177 (The Robettes)
Team Role: Electrical
amariealbrecht has a spectacular aura aboutamariealbrecht has a spectacular aura aboutamariealbrecht has a spectacular aura about
Send a message via AIM to amariealbrecht
From another team that is clearly a fan of pink....thats very cool and I love the design. Good luck to you all in the rest of the season!
Alicia Albrecht
Team Captain, 2009
THE ROBETTES
  #33   Spotlight this post!
Unread 11-03-2009, 21:29
IBdrummer's Avatar
IBdrummer IBdrummer is offline
AKA: Beau Muniz
FRC #5492 (Winners Circle Robotics)
IBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of light
Originally Posted by Snapalope View Post
you guys might have to reinforce the front of your bot above the suck up roller.
we had to triple stack eight inch angle on each side of our robot after coming back from a match and they were both bent in a solid 1/2 an inch
We have a steel tube above it for structural suport
  #34   Spotlight this post!
Unread 11-03-2009, 21:30
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
any video?
cant wait until tomorrow
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
  #35   Spotlight this post!
Unread 11-03-2009, 22:02
ducttapedude ducttapedude is offline
AKA: Peter
FRC #0233 (The Pink Team)
ducttapedude has a spectacular aura aboutducttapedude has a spectacular aura aboutducttapedude has a spectacular aura about
Send a message via AIM to ducttapedude
Originally Posted by sdcantrell56 View Post
If any team can pull off a shooter without an adjustable hood it will be you guys. I hope it works for you. How many balls per second can you guys shoot and do you have the tracking working well?
Also just curious...how much sheet aluminum do you guys go through?
We use a lot of sheet metal and box tubing, but we focus a lot on using as much scrap as possible, that means jetting out every little plate on left overs as often as possible, and using scraps that are up to 6 years old.
Originally Posted by hillale View Post
Just curious, but why did you abandon the human loaded hopper? Orbit balls getting jammed going into the shooter feed?
Originally Posted by 1086VEX View Post
how far does your turret rotate, and how many balls can it hold?
Looks like another amazing bot from 233!! hope to see you in Atlanta!
oh...are the bumpers at least pink?
Those two questions are connected.
The reason we have modified our original design is so that we can actually shoot almost directly behind us. The hopper originally limited us to aprox 180 degrees, we should have aprox 270 degrees after this modification.
We will still have a hopper, just not as dominating of one.
Think Poof
  #36   Spotlight this post!
Unread 12-03-2009, 03:16
ShaneP's Avatar
ShaneP ShaneP is offline
Lead Mentor
FRC #0330 (The Beach Bots)
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
The first thing that came to my mind was the same feeling I get when looking at all the different supports and structure of a wooden roller coaster. This is an impressive looking robot, and I hope I can get the chance to see it in person. Good work 233!
  #37   Spotlight this post!
Unread 12-03-2009, 11:04
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
I can just imagine carrying those 50lb bags of abrasive back and forth to fill up the abrasive container for the jet. I wish that I had the time to pull that one off, especially because it looks almost as if the sides are solid cut from a 4x8.... Amazing.... Did the students on your team just not go to school? Sorry, but I really am sitting here at my computer yelling “HOW?” I can just remember the hundreds of hours sitting at the jet watching it blow water and sand in my face and pulling pieces out so it didn’t destroy its own tip. Great job guys, I don’t know how these kids pull this off every year, but major props to all of you… I worked extremely hard with my team all season every second i had, and still could not create something of this magnitude. I am a senior now, and I still look back to this season and wonder where I could have had more time… This truly is an amazing work of art. Good luck at competitions.
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
  #38   Spotlight this post!
Unread 12-03-2009, 21:08
gorrilla's Avatar
AKA: adam spears
so why was it in pieces today?
Adam Spears
  #39   Spotlight this post!
Unread 12-03-2009, 22:37
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
I was talking to them and they said it was because they kept about 38 lb of parts at their shop and brought them with them today because they built close to 2 robots but some of the parts were just too complex and time consuming to make 2 so today they had to put it back together.
  #40   Spotlight this post!
Unread 12-03-2009, 23:54
POWSpyder's Avatar
POWSpyder POWSpyder is offline
Chris1622
AKA: Chris Holliday
FRC #1622 (Team Spyder)
POWSpyder is an unknown quantity at this point
There's a lot going on in there! I take it you guys are going to be using the camera? Very cool design non the less. How you do well.
"Seek and Destroy" that says everything about the robot.
pic: Roccobot 2k8 233 gearbox ducttapedude Extra Discussion 8 05-05-2008 08:40
pic: THINK PINK Roccobot 2k8 Gabe Salas Jr. Extra Discussion 14 15-03-2008 20:54
Team 233 (The Pink Team) Roccobot 2k7 Videos Unveiled! Gabe Salas Jr. Robot Showcase 49 14-03-2007 09:49
Team 233 (The Pink Team) Roccobot 2k6 Video Unveiled! Gabe Salas Jr. Robot Showcase 28 02-03-2006 22:24
pic: 233 Roccobot (almost done) CD47-Bot Robot Showcase 1 26-03-2004 10:54
