Go to Post Has FIRST ever made a game that was easy to do? - Koko Ed [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 19-10-2001, 15:56
Andrew Foster Andrew Foster is offline
#0448 (Crandroids)
Andrew Foster is an unknown quantity at this point
Wiring Diagram
Would anyone know where to find a wiring diagram for the electronics box? Please post
Andrew Foster
Unread 19-10-2001, 18:16
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Wiring
Why do you need a diagram. the box is pre-wired.
What type of problems are you having?
Ask and Justin or Mike McIntyre will answer. I might if I know the answer. I did not assemble the boxes.
Mike Martus
Unread 21-10-2001, 12:36
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
I suppose if you were to accidentaly pull out a connection somewhere, you might need a diagram, or if you needed to know which PWM's went to which Victors, and so on.
Unread 21-10-2001, 12:58
Diagram
Very good reason.
Hey Justin Howard can you post the diagram?
Mike Martus
Unread 21-10-2001, 19:04
El Jefe de 148
I'm so good
Competition port Wiring diagram Joe Clohessy Technical Discussion 14 20-05-2003 12:14
Optical sensor wiring with the EDU Robot Geoffrey4283 Electrical 3 15-01-2003 21:03
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
What is the wiring for the FESTO valve? Nuts4FIRST Technical Discussion 4 12-02-2002 17:14
