Go to Post Sleep is for the weak - TEntwistle [more]
Unread 13-03-2009, 15:35
Jared Russell's Avatar
Taking a year (mostly) off
Re: strcat error
I think you think that strcat does something that it doesn't. You can't just cast an int to a char * and expect it to work.
How about:
 int loop=0;
while (IsAuto())
     printf("%d iteration\n", ++loop);
That is the most direct way to accomplish what you want. Alternatively, here's how to do it with strcat() properly:
 int loop=0;
while (IsAuto())
     char msg[100]; // We can't just declare this as a "char *" without first allocating memory - 100 characters is more than enough
     strcat( msg, itoa(++loops) );
     strcat( msg, " iteration\n");
     printf("%s", msg);
The standard C itoa() function takes an integer and returns a C string of the printable characters.
LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi RMS11 Programming 8 08-12-2008 18:20
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
