Go to Post Thank you for Recycle Rush, the largest FLL game ever. - Dan Petrovic [more]
Unread 13-03-2009, 15:47
Jared Russell's Avatar
Taking a year (mostly) off
Re: Timing belt size
You can even get by with a 20DP gear in a pinch. Our shooter/dumper is powered by a CIM with a 12-tooth 20DP, 14.5PA gear from a first generation AM Shifter. The 15mm wide, 5mm pitch belt fits into the profile perfectly and we have NEVER had any issues with that aspect of our system.
Splice Timing Belt comphappy Technical Discussion 4 07-02-2009 09:37
timing belt ordering XXShadowXX Technical Discussion 3 26-01-2008 17:01
Timing Belt Clamp shorton Technical Discussion 10 18-07-2006 22:50
two sided timing belt archiver 2001 3 23-06-2002 22:34
Timing Belt Recommendations? Eric Reed Technical Discussion 1 10-01-2002 00:25
