Go to Post I hate having to wear official pants. - Cothron Theiss [more]
Unread 13-03-2009, 15:27
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
strcat error
testing out some code, our auto looked similar to this:
 int loop=0;
while (IsAuto())
     char * name = strcat((char*)(++loop), " iteration");
     printf(name);
and I run kernel task, downloads, open console, see nothing, on ds, auto enable, and the console prints out nothing and the ds then says no comms. the RSL was solid, but we had to restart. the strcat seems to be crashing the robot, is this possible? and why?
Watchdog.Kill();
Unread 13-03-2009, 15:35
Jared Russell's Avatar
Taking a year (mostly) off
Re: strcat error
I think you think that strcat does something that it doesn't. You can't just cast an int to a char * and expect it to work.
How about:
 int loop=0;
while (IsAuto())
     printf("%d iteration\n", ++loop);
That is the most direct way to accomplish what you want. Alternatively, here's how to do it with strcat() properly:
 int loop=0;
while (IsAuto())
     char msg[100]; // We can't just declare this as a "char *" without first allocating memory - 100 characters is more than enough
     strcat( msg, itoa(++loops) );
     strcat( msg, " iteration\n");
     printf("%s", msg);
The standard C itoa() function takes an integer and returns a C string of the printable characters.
Unread 13-03-2009, 18:15
byteit101's Avatar
Re: strcat error
ok, but why is it crashing the crio?
Watchdog.Kill();
Unread 13-03-2009, 19:02
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: strcat error
You're taking the loop number and treating it like a pointer , so the rio is trying to access memory at the address of 'loop', which is probably 0 or very low. Basically you're causing a segmentation fault, which probably causes your task on the rio to exit.
Unread 13-03-2009, 21:38
byteit101's Avatar
Re: strcat error
ahhh! that would explain that! doesn't one love the power and the unsafeness of C/C++? (there's an easy virus: ((char*)0) = "CORRUPT THIS DATA!!!!"; )
Watchdog.Kill();
Unread 13-03-2009, 21:47
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: strcat error
Actually, if you're running as a normal process on a modern operating system, that will only crash the individual program that did the bad access. Like in Windows when you see "X has encountered a problem and needs to close... ", many times the reason it needs to close is because of bad memory accesses. On a *nix box you'll see something on the screen saying 'segmentation fault'.
Now of course, if you're running in the kernel and make a bad memory access, then the system will generally crash, since theres nothing to protect you there. Incidentally, our programs are running as a kernel module on the cRio...
Unread 13-03-2009, 22:37
Re: strcat error
Pointers are a great and terrible thing. To the point that I've worked on many projects at work where the use of non-smart pointers is strictly prohibited. Simply put, 90% of us aren't smart enough to use them effectively without shooting ourselves in the foot (and I am definitely a member of that majority!)
LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi RMS11 Programming 8 08-12-2008 18:20
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
