Go to Post They had me at "chocolate-covered bacon".... - Foster [more]
Unread 13-03-2009, 19:02
shaggy0928 shaggy0928 is offline
FRC #1339
shaggy0928 is an unknown quantity at this point
No longer can build with Lab View after downloading update 3.
We recently downloaded the mandatory update 3 from usfirst.org and after that we get the message:
Error 1327 occurred at mxLvErrorHandler.vi:1
Possible reason(s):
LabVIEW: The specified NIIM is invalid for the current project.
This is paired with the problem of this happening when we try and build we get the error that "The plug-in for the selected item is not installed on your system."
What have we done wrong? and is there any fix that we are missing?
Unread 13-03-2009, 19:10
Re: No longer can build with Lab View after downloading update 3.
The error message isn't great, but it almost sounds like your code is being built for the PC rather than the cRIO. To debug, open an example, set the address, and see that they run correctly. Perhaps make a new project and see if it builds. If your code is listed under the My Computer rather than cRIO, drag it to the cRIO target.
Greg McKaskle
Unread 14-03-2009, 10:03
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Use the NI License Manager to reactivate your copy of LabView.
Located off the National Instrument menu.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Lab View Update 3.0 encoder trouble Funnyman2003 Programming 2 03-02-2009 08:52
Help with programing Tank Drive in Lab View zackcool123 NI LabVIEW 3 18-01-2009 19:49
Vex and lab view 1086VEX Programming 2 02-06-2008 20:42
Lab View Schotty57 Programming 5 02-04-2008 20:24
Any teams build two robots to practice with after build season. (6 weeks) GVDrummer General Forum 42 24-01-2008 21:34
