Go to Post Oh, and your t-square and pencil can't crash, unlike your laptop :D - scottydoh [more]
Unread 13-03-2009, 22:28
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: [FTC]: Common failures with TETRIX
All four of my motors burned out, this really irritated me and I'm making sure this never happens again. I recommend having touch sensor bumpers around your robot to make sure your motors aren't stalling. I'd recommend not going past 60-80% motor power for a a few seconds.
Our axle heated up on the motor and is now force fitted onto my encoder and hub. Waste of a motor...
For a $25 dollar motor, and in a rough competition the motor tabs you hook up to, are way too thin and feeble. I lose a motor because of a lost tab. I am however happy.
I recommend checking over your motor and servo controller, the signals being sent to it, with a logic analyzer (I use the Saleae one, very good and affordable, http://www.saleae.com/logic/).
Queuing your controller takes way too long, I don't think a regional has gone by without FMS issues, they really need to improve this. Teams need to be enforced about the bluetooth rules and how your NXT should be prepped.
The lack of sensor ports is extremely limiting. LEGO Motors can be difficult to attach, I usually have to do it by a zip tie and a flimsy beam. Although proved that with regular NXT models the size and form of the NXT motors can be taken advantage of, it's just not right for Tetrix.
All of the wires should definitely be of a lower gauge. That being said some of them are of a low gauge and end up not fitting in the motor controller's terminals without crimping or trimming.
My complaints to HiTechnic on the motor controllers, although a great thing to have for NXT fans, these are poorly made and priced. It is not a professional motor controller, and is definitely not as industry standardish as the rest of the kit. It's a simple H-Bridge circuit with some power transistors! Maybe $10 dollars worth of parts, not $64 dollars!! And the lack of indicator LED's is frustrating.
As for the Tetrix metal, although I love it's amazing strength and extremely light weight, it's overkill for FTC. The hole pattern and sizes of tubes and channels are suiting, I was satisfied with those aspects. The amount of metal that came with the kit is extremely pleasing, I can build an entire competition robot with it.
I don't like the size of standoffs. 1" and 2" doesn't exactly fit the hole patterns and widths of channels. They should be 1.25 and 2.25".
Having to buy multi nut pliers separately as some form of wrench that the original kit lacked was a disappointment. As with Vex, a kit that's meant for a team of 3-10 only came with 1 set of hex wrenches. Luckily they were somewhat commonly available sizes.
We weren't told on what setting to charge the battery at. For many teams there was a punishment to FIRST's lack of documentation.
Although high resolution and lovely to program, the encoders are way overpriced.
Anybody else had their servo bushings (the axle thingy that attaches to the horn) ware out beyond repair? Although somewhat my fault ( ) this was a huge annoyance and the servo's were surprisingly weak (doesn't really match the whole "real world application robotics" theme).
There wasn't really a reliable way to attach the battery or the on/off switch. Zip ties worked but not really to satisfaction. I believe the kit came with one velcro strap to hold the battery in place. One doesn't exactly do the trick for the weight and size of the battery.
How often have you got a hub stuck on an axle and you have to yank it out with two heavy duty pliers? For strong metal gears the teeth sure ware out, luckily still working and pretty much no skipping yet I'm not sure how many months of competition they would last.
I think everybody has tried out the pivot bearings only to find out the screw is too small to fit through the required amount of metal!
Back to lego to metal connections. I hated how the hard point connectors was only wide enough to fit a lego beam in one orientation. They could've also had a different form of hard point connector where it fits between two beams (i.e. the bottom of a lego motor).
Final complaint, how many people got their design screwed over by the backorder of motor contollers???
Sorry for the overly long post. Enjoy?
[FTC]: Cutting Tetrix Metal blackbrigadeer FIRST Tech Challenge 3 12-01-2009 08:56
[FTC]: Use of VEX in Tetrix ttldomination FIRST Tech Challenge 7 11-01-2009 17:42
[FTC]: FTC Tetrix Extra Parts Team 288 FIRST Tech Challenge 2 22-10-2008 18:30
[FTC]: Asdst Tetrix Help sovierr FIRST Tech Challenge 2 22-10-2008 16:12
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
