strcat error
testing out some code, our auto looked similar to this:
int loop=0;
while (IsAuto())
char * name = strcat((char*)(++loop), " iteration");
printf(name);
Re: strcat error
I think you think that strcat does something that it doesn't. You can't just cast an int to a char * and expect it to work.
How about: Code:
int loop=0;
while (IsAuto())
printf("%d iteration\n", ++loop);
int loop=0;
while (IsAuto())
char msg[100]; // We can't just declare this as a "char *" without first allocating memory - 100 characters is more than enough
strcat( msg, itoa(++loops) );
strcat( msg, " iteration\n");
printf("%s", msg);
Re: strcat error
ok, but why is it crashing the crio?
Re: strcat error
You're taking the loop number and treating it like a pointer , so the rio is trying to access memory at the address of 'loop', which is probably 0 or very low. Basically you're causing a segmentation fault, which probably causes your task on the rio to exit.
Re: strcat error
ahhh! that would explain that! doesn't one love the power and the unsafeness of C/C++? (there's an easy virus: ((char*)0) = "CORRUPT THIS DATA!!!!";
Re: strcat error
Now of course, if you're running in the kernel and make a bad memory access, then the system will generally crash, since theres nothing to protect you there. Incidentally, our programs are running as a kernel module on the cRio... |
#7
Re: strcat error
Pointers are a great and terrible thing. To the point that I've worked on many projects at work where the use of non-smart pointers is strictly prohibited. Simply put, 90% of us aren't smart enough to use them effectively without shooting ourselves in the foot (and I am definitely a member of that majority!)
| LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi | RMS11 | Programming | 8 | 12-08-2008 06:20 PM |
| Error in code light on, trouble finding error | Bryan Herbst | Programming | 16 | 10-12-2007 09:59 PM |
| 180:Error: syntax error help! | seanl | Programming | 8 | 02-04-2007 11:31 AM |
| stupid Array error: Error [1300] stack frame too l | Validius | Programming | 7 | 01-27-2006 10:53 AM |
