Go to Post In the end engineering is what happens between your ears, not what you build with your hands, not what a machine spits out. - KenWittlief [more]
Unread 14-03-2009, 19:13
chopperdudes's Avatar
chopperdudes chopperdudes is offline
zizzling battery
FTC #0541 (Jaguars)
Team Role: Driver
chopperdudes is an unknown quantity at this point
[FTC]: number of sensors?
Hi every1, i was wondering... since there's only 3 ports on the nxt for sensors, is the maximum number of sensors 3? (besides touch which you can use the Multiplexer).
is there any ways to for example, use 3 light sensors, compass, and a sonar?
thx
Unread 14-03-2009, 19:19
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: [FTC]: number of sensors?
There is no multiplexer available to do what you wish to do. You can only have 3 sensors (or 2 sensors and 4 touch). However you can use a HiTechnic prototype board (http://hitechnic.com) and with the right circuit you could develop your own mutliplexer. You could also hook up light sensors to it (any sensor that uses a low amount of current (a single NXT port only supplies so much current and you cant use external batteries)).
What are you wishing to use the 3 light sensors for? If you want to make an array of light sensors for a line follower you should know that it's very easy (and sometimes even more efficient) to make a line tracker with a single light sensor.
Unread 14-03-2009, 19:20
Emily Horsman
P.S. I have an untested theory that given the values that NXT sensors send it might be possible to use light sensors with the touch sensor multiplexer but it probably would only be able to do a one bit value (dark or light).
Unread 15-03-2009, 13:59
zizzling battery
FTC #0541 (Jaguars)
Team Role: Driver
thx! hmm okay then i'll only use one light, but probably not for the line tracking. i'm thinking of doing direction auto correcting with compass. but the problem is... if we're soo unlucky to get a direction near 0... then the correcting might take abit more code.
[FTC]: Rhode Rage (FTC 121) is in need of a motor encoder wire Rick FIRST Tech Challenge 2 02-02-2009 01:56
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Number of sensors in the IR Pattyta Programming 3 25-03-2004 18:00
