Go to Post So basically, the advantage of #35 is that it allows you to be sloppier in your design and fabrication. If you pay close attention to these details, you will never have a problem with #25 chain. - Jim Zondag [more]
Unread 02-03-2009, 17:50
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
pic: Team 2022's Drivebase
Unread 02-03-2009, 17:52
Swttrt224's Avatar
Swttrt224 Swttrt224 is offline
System Integrator
AKA: Caitlin
FRC #2022 (Team IRS (IMSA Robotics Specialists))
Swttrt224 is a glorious beacon of lightSwttrt224 is a glorious beacon of lightSwttrt224 is a glorious beacon of lightSwttrt224 is a glorious beacon of lightSwttrt224 is a glorious beacon of lightSwttrt224 is a glorious beacon of light
Send a message via AIM to Swttrt224
Smile Re: pic: Team 2022's Drivebase
What a BEAST of a drivebase....some genius must of invented that...
oh wait, HA, I invented that... lol :-)
It's amazing that we were easily able to push around Wildstang's 4 CIM swerve with traction control AND Winnovation's tank with traction control...
$TEAM IRS #2022$
2009 Season:
MWR semi-finalists
FWR TBD
2 weeks until salvation...again
Unread 02-03-2009, 17:57
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
so only 1 cim for all 4 wheels? or one for each wheel?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 02-03-2009, 18:05
Chains=Fun
1 CIM total
Unread 02-03-2009, 18:07
gorrilla's Avatar
AKA: adam spears
Originally Posted by big1boom View Post
1 CIM total
wow, what transmission are you using?
Adam Spears
Unread 02-03-2009, 18:48
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Where else were you using your CIM motors?
Unread 02-03-2009, 19:03
Chains=Fun
Standard toughbox transmission, then chain sprockets set up as follows 15:9:bevel:11:22
We only have 1 other CIM and it is on the power dumper.
Unread 02-03-2009, 19:08
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Why only use one CIM on the drive then? Were there weight or space issues?
Unread 02-03-2009, 19:13
Chains=Fun
We did the calculations, and 1 CIM would provide more than enough torque to skid the wheels. But then when it was tested at Midwest, we have just enough torque to get nearly maximum acceleration. But we do not have enough to spin our wheels. This means that we are always in static friction. So we actually have better traction than bots that have to use sensors and traction control code. This is why we were able to push around Wildstang, who have 4 CIM's and active traction control.
We could throw a 2nd CIM in. But as it is now, the CIM does not overheat, we have maximum traction, and fairly good acceleration. So why change?
Unread 02-03-2009, 19:34
CJmango's Avatar
CJmango CJmango is offline
AKA: Christopher Jones
CJmango is an unknown quantity at this point
Send a message via AIM to CJmango
Wow, that is awfully insightful. I'm always a fan of bigger and more powerful but this year I think you've got the right idea. All of these other teams are spending their energy developing software to limit their beefy drivetrains, instead you avoid designing a beefy drivetrain in the first place.
The active traction control is still a disadvantage because in most cases, in order for it to activate, the wheels have to slip. Pushing the slip boundary like that makes it easier to push them if you're solidly in static friction.
That picture also blows up nicely, but I don’t think we can see the bevel gears in the housing. Do you have any pictures from the assembly process?
Kudos on a crazy cool design.
Unread 02-03-2009, 19:41
Chains=Fun
Thanks for the complement.
I will try and find a picture of the inside of the box.
Unread 02-03-2009, 19:49
Chains=Fun
Pretty big image so I will just link to it.
http://i43.tinypic.com/nd6a90.jpg
Here is a small version.
That is the best picture that I can find. We didn't take any intentional pictures of the wheelbox's.
Unread 02-03-2009, 20:28
spage spage is offline
FRC #2022 (IRS)
spage has a spectacular aura aboutspage has a spectacular aura about
Just because your driving me up the wall Swttrt224 by taking all the credit I would Like to lay down the blame for this drive train and answer others questions.
Firstly, this drive train is the result of a study swttrt and others including myself did last year. The math for the gear ratio with some real world tweaking is swttrt's, the actual drive train that was cut by a student on the team and framing around the drive train that was built by big1boom was all Cadded by me. As such why I am extremely disappointed when all the credit for this drive is taken by one over zealous member.
An additional note that I would like for other members of my team to understand is that they must remain gracious professionals when on these forms and need to stop gloating. Is it true that this drive train has yet to find a match that can push it as adequately, yes. Is it true that this robot did not win the Midwest regional, yes. Is it true that my members have just explained exactly why we have so much traction, yes. Do I expect that because of their posts we will have lost our advantage, yes.
Since they have been so forward about our robot I feel that It is only right to post up some CAD's I drew. These Cads where used to build our drive train. I will try to explain what was used for what.
This is the original idea before we found out that Caterpillar could not produce any parts for us due to economic issues.
So we made a frame that looks like this with the same chain and electrical Ideas as previous.
we actually milled these with a 20 year old cnc that we got working 2 weeks before ship and taught ourselves how to cut. Not the notches that allow our bit to make right angles where we need them. - this was milled by both 1/8 inch and 1/4 inch end mills. Thanks to my sophomore team that learned how to run the machine we finished on time.
Those last 2 should give you an idea of the bevel gear set up, the plates are placed so that they keep the bevel together while taking into account the bushings.
The aluminum is just 1/8 in thick, and thank goodness cause it helped keep the weight down.
The lazy suzans are from mcmaster.- a note to my sophomore's as I will me graduating this year, use a smaller chain next year.
I had a great time cadding this, and It really helped modularize our build cause it stated the exact placement of the ball system and electrical.
Unread 02-03-2009, 20:32
FRC #2022 (IRS)
How much more practice will it take before I am able to get a job with some drafting company?
Unread 14-03-2009, 21:03
Kat Kononov's Avatar
Kat Kononov Kat Kononov is offline
AKA: artqny
FRC #2022 (Team IDK)
Kat Kononov is an unknown quantity at this point
Send a message via AIM to Kat Kononov
Thumbs up Re: pic: Team 2022's Drivebase
scott, i'm really impressed with your CAD drawing. don't lose this skill.
pic: EngiNERDs - Team 2337 - Team Work After Ball Popped Clinton Bolinger Extra Discussion 3 23-02-2008 23:10
pic: Dawgma 1712 NEW and IMPROVED Drivebase Chuck Glick Extra Discussion 4 13-01-2008 15:30
pic: Team RoboRaiders(75) and Team Mu Mu Psi(2016) versions 2007 Rohith Surampudi Robot Showcase 5 22-02-2007 08:43
Team 1425 Drivebase and Wiring Sparks333 Robot Showcase 5 05-02-2007 10:41
pic: Team 334 Team Members after the CeBit Convention CD47-Bot Extra Discussion 2 29-05-2004 14:14
