Go to Post So the bar is set insanely high. Probably unachievably high for some of us. But what a shame it would be to lower it. - pfreivald [more]
Unread 14-03-2009, 21:51
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
Re: Case Structures
Originally Posted by Garii View Post
Cases are extremely versatile, all you have to do is wire something to the boolean case node and it will switch to what ever you wire it to. the only other things I'd like to add is that if your doing an array or something like that that the case doesn't always add all the variables available
in that case, you right-click and select 'add case after' and it should create a new case with the next variable in the array
Unread 15-03-2009, 10:50
Re: Case Structures
Just to keep the terminology clean, cases/switches don't do arrays at all. The string and enum have a set of values they support, but the thing wired must be a scalar, not an array.
In the case of the enum, it may be useful to use the popup for creating all cases at once, otherwise use the Add before or Add after.
Greg McKaskle
paper: FIRST Drive Trains and Structures Madison Extra Discussion 18 04-12-2007 17:37
Green light Case Lablabla Technical Discussion 9 16-01-2007 21:53
Compiler has troubles with structures? steven114 Programming 1 21-02-2006 18:28
Question: Carrying Case UIDzero Technical Discussion 10 10-11-2003 14:35
Bone structures x_cat_SHAUN 3D Animation and Competition 1 11-02-2003 18:57
