Go to Post FIRST is good for us. It is good for our own Children. Don't give up, even if you are as tired as I am! - Kyle Hughes [more]
Unread 15-03-2009, 14:56
Abra Cadabra IV's Avatar
Abra Cadabra IV Abra Cadabra IV is offline
Still spinning in circles
AKA: Katy W.
FRC #2429 (Blockheads), FTC #25 (Rock-n-Roll Robots)
Abra Cadabra IV is just really niceAbra Cadabra IV is just really niceAbra Cadabra IV is just really niceAbra Cadabra IV is just really niceAbra Cadabra IV is just really nice
Re: First Time in Atlanta
I think the walk will be a bit better this year; last year they had to deal with tornado damage on top of everything else and I think the route we had to take from the pits to the dome was affected by it. However, it's still going to be a long walk. DEFINITELY invest in something to help you carry your robot. Last year we made that mistake and spent a couple matches hand-carrying our 20lb robot to the field and back until we found a collapsible luggage dolly (which I do NOT recommend using except as a last resort). Even if your robot's light, it's a long walk and you don't want to risk dropping it.
In regards to matches, I think last year each team got 7 or so. They also gave us 2 practice matches at the beginning of the first day, which I don't think were included in the total of 7.
Also, if the scheduling is anything like last year you might not get much time to visit the FLL pits or matches. They run on roughly the same schedule as FTC, if I remember correctly, and if queuing is the same as it was last year then you're going to spend a lot of time in the Dome waiting for your match. (Last year the matches ended up delayed by a good hour or so but teams were being queued according to the original schedule.) But even with this, you'll still have an entire day to watch FRC matches. The final matches in particular are definitely worth seeing, especially if you're lucky enough to get good seats.
Overall, Atlanta is a wonderful experience and definitely worth the trip. It sounds like you and your dad are pretty well prepared for this, but if you run into trouble other teams are usually willing to help out, lend parts, or even share scouting information. Good luck, and I'll see you there!
Proud alumna of:
FRC Team 2429 - Blockheads
and
FTC Team 25 - Rock 'n' Roll Robots
Unread 15-03-2009, 16:24
rspurlin's Avatar
rspurlin rspurlin is offline
AKA: Ray Spurlin
FRC #1379 (Gear Devils)
rspurlin has a spectacular aura aboutrspurlin has a spectacular aura about
The configuration of the facility and the logistics could be different from previous years, but assuming no weather related massive changes ... The FTC fields will be in the Georgia Dome on either side of the fifty yardline. There will be two FRC fields on either side of you (sort of in the corners of the field/floor). I think if you look you can find typical layouts and maps online somewhere. The pits will be in the adjacent building, the Georgia World Congress Center, one of the largest exposition centers in the world. Plan to spend lots of time walking between venues. Even so, this is one of the few places in the world with such facilities adjacent to one another.
Although others have suggested that there is any easy path from the stands to the floor of the Dome, FIRST strongly discourages people from making such a move. Do not count on being able to do this. I second the recommendation that you have your father act as coach and come along with you on the walk from the pits to the field. His view will be much better also.
As FTC and FLL are mostly running simultaneously, you won't have much time to view FLL stuff. Assuming the pits are laid out as they were in previous non tornado affected years, you'll be close enough to visit their pit areas though if you have some spare time between matches.
Atlanta is a big city like most others. There are certainly parts of town that are nicer than others. I can't vouch for specific hotels where it may be safer to leave certain valuables, as I live here, but use common sense. Strangely enough, comments about laptops being safe in the pits during the event are mostly true. But I wouldn't leave a laptop bag unattended anywhere outside the venue, regardless of what city I'm in.
You should have time to visit friends, and I'll also recommend you host them in visiting the FRC events on Saturday. Maybe you'll be able to show off a trophy.
Congratulations on the invite and good luck on making the most of your trip.
Unread 15-03-2009, 19:04
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Thanks again everybody,
Is there open wi-fi in parts of the convention centre and dome?
Unread 15-03-2009, 21:19
Phil Ross's Avatar
Phil Ross Phil Ross is offline
Constantly Inspired
FRC #1712 (Dawgma)
Phil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to behold
Send a message via AIM to Phil Ross
in the past there has been. although this year I would not count on it because of the new FTC and FRC field controls. The FRC rules have said that there is to be none of that stuff. At some regionals there have been designated areas for Wi-Fi. Hopefully there will be some sort of "cyber-cafe" for people to use.
Good luck and see you in ATL!
FIRST Americorps VISTA, Philadelphia
DAWGMA TEAM 1712: Alumni (2006-2009)
Unread 15-03-2009, 21:28
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
I've always enjoyed this view of a walk to the pit: http://www.youtube.com/watch?v=YSjKVDgnWwY. We never quite made it in 37 seconds!
He is no fool who gives what he cannot keep to gain that which he cannot lose. - Jim Elliot
Unread 15-03-2009, 22:03
Overyourhead's Avatar
Overyourhead Overyourhead is offline
Josh
AKA: Josh
FTC #0154 (Renegade)
Overyourhead is a jewel in the roughOveryourhead is a jewel in the roughOveryourhead is a jewel in the rough
Send a message via AIM to Overyourhead
Last years walk for FTC wasn't nearly that long. The only part we walked was starting at 20 seconds in your video. Because of the tornado last year the pits were a lot closer than previous years. I hope this year the FRC pits and the FTC pits are in the same hall again. It makes the pits a lot more interesting.
For anyone who doesn't know. A tornado hit Atlanta a few weeks before the championship. It was pretty much cleaned up by te time we got there. Alot of windows were blown out all around the city. Here is a picture of the Dome as we drove up. All the plywood should have been windows.
Also, for anyone who has never been to the Dome. Here is a short video about it. There's a lot about the Dome I didn't know.
http://www.youtube.com/watch?v=9uBBT9EhYxU&NR=1
"Like the WWF, but for smart people." -George HW Bush
2008-2009 Team 154 FTC
RI Regional-Winning Alliance/PTC Design Award
18th Place in Atlanta (Franklin Division)
2007-2008 Team 154 FTC
Winning Alliance/Inspire Award -RI Regional
Semi-Finals MA Regional
Atlanta Quarter Finials 12th in division(Franklin Division)
2006-2007 FVC 3707
Winning Alliance/Connect Award-RI Regional
26th Place in Atlanta
Unread 15-03-2009, 22:12
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
They left out the part that the dome roof can easily support the weight of a M1 tank.
Not really related, but I didn't realize that apparently Atlanta is considering a new stadium for the Falcons. I guess once a Stadium gets to be close to 20 years old its warranty expires. Or something.
Unread 15-03-2009, 22:25
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
this year is going to be 1557's first year at the championship!!!
that a really long walk
we probobly modify our cart a bit so i can hold tools and so we can charge batteries from it and stuff
I forgot to ask the question lol
theres an after party for all the teams right? when does it start and end? is it worth going too and staying another night in atlanta?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 15-03-2009, 22:30
BenX02's Avatar
BenX02 BenX02 is offline
FRC #2655 (The Flying Platypi)
Team Role: Driver
BenX02 has a spectacular aura aboutBenX02 has a spectacular aura about
It is a giant place, I was there in 2005 with my FLL team, and it took us about 5 minutes to get to the playing field from the pits.
Unread 15-03-2009, 23:03
Josh
AKA: Josh
Congrats on going to Georgia.
The walk is long...but manageable. As for the cart, you can definitely do that. There seems to be a secret cart war that goes on between teams. I've seen carts with strobe lights and a fog machine. I've also seen a hovercraft cart. That was pretty Epic.
Yes, there is an after party. It starts right after the FRC finials on Einstein. The party is cool....but I don't think it is worth staying an extra day. My team takes a bus down there with another team from our state. We stay for about 2 hours then leave for home. If you can't make it I'd say just go home. If you can only go for an hour or so it's worth getting the meal and playing a few games. I'm not sure what time it ends....I've never stayed that long.
2006-2007 FVC 3707
Unread 16-03-2009, 03:25
ptan ptan is offline
Paul C. Tan., P.Eng.
AKA: Paul Tan
no team (Bolt Action)
ptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to behold
... We have raised enough money to go to the Atlanta championships that we were invited to via the second round lottery pick. We're driving to Atlanta from Toronto.
Congrats on making it in!! We enjoyed having you as our alliance partner and we look forward to seeing you guys again in Atlanta!
As far as logistics goes, we are actually planning on leaving our robot at the FTC pits, however, we are locking it up inside a box. Also, we are planning to bring the cart you saw us push around at the Ontario FTC Tournament. Having been to Atlanta a few times before as an FLL team, we know how long the walk from the pits to the dome is! You really don't want to be carrying your robot by hand all that way.
Don't forget to hang around for the Canadian Team group picture -- All the Canadian FLL/FTC/FRC teams gather around for a picture together. Also, in previous years, we had a reception for Canadian Teams. I don't know if there is plans again for it this year.
As far as visiting the FLL and FRC teams, the schedules will be tight. You'll be fairly busy with your matches. I remember last year when we went down as an FLL team we wanted to watch some of the FTC matches, but our schedule was just too tight. I assume the FTC schedule would be just as tight.
Feel free to email to call me if you need further information (just email me through Chief Delphi and I'll respond with my contact info).
Coach - FTC Team 27 (now retired)
Coach - VRC Team 2027 (now retired)
Past Mentor - FRC Teams 188, 610, 1009, 2634
Unread 16-03-2009, 10:14
dman14 dman14 is offline
AKA: Darren Stahl
FRC #4783 (FRC #1305 Alumni)
dman14 will become famous soon enoughdman14 will become famous soon enough
gratz 168, it was great to play with and against you, good luck in atlanta
Unread 16-03-2009, 10:26
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Exclamation Re: First Time in Atlanta
Pit setup and registration is on Wednesday afternoon in Atlanta. Make sure you are there for that.
Like Aquidneck Island Robotics on Facebook!
What time does your flight land in Atlanta? And what day? Elgin Clock Championship Event 90 11-04-2007 12:32
Any Atlanta First Time Traveler Tips you want to Share? Chris_Elston Championship Event 60 04-04-2007 11:59
**FIRST EMAIL**/Reminder - Call for Proposals, FIRST Robotics Conference in Atlanta Pat Fairbank FIRST E-Mail Blast Archive 0 12-12-2005 15:18
**FIRST EMAIL**/Call for Proposals - FIRST Robotics Conference, Atlanta, April 27-29 KathieK FIRST E-Mail Blast Archive 0 16-11-2005 17:09
**FIRST EMAIL**/Call for Proposals - 2005 FIRST Robotics Conference in Atlanta, Apri Rich Wong FIRST E-Mail Blast Archive 1 06-12-2004 10:52
