Go to Post If you look closer, you'll see I did those photos over a period of years... and they were only done with one program... but yeah, a little free time with no where to direct it and I can become, um, creative... - MissInformation [more]
Unread 15-03-2009, 18:21
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
pic: 1717 in the Finals
Unread 15-03-2009, 21:39
115inventorsam's Avatar
115inventorsam 115inventorsam is offline
Inventorizer
AKA: Sam Wu
FRC #0115 (MVRT)
115inventorsam will become famous soon enough
Send a message via AIM to 115inventorsam
Re: pic: 1717 in the Finals
Quite an impressive robot. I certainly can't wait to see it in person at Davis.
MVRT's Website The 2008 Championship Best Website Award Winner
Once a student, now merely an observer.
Unread 15-03-2009, 22:08
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
one of my favorite teams, beautifully designed robot. i really like the power chain going to the hood.
Unread 16-03-2009, 14:09
GabeRC1717's Avatar
GabeRC1717 GabeRC1717 is offline
FRC #1717 (D'Penguineers)
Team Role: Student
GabeRC1717 is on a distinguished road
Thank you, we found the energy chain to be a very clean and effective wiring solution for our turret.
Gabe
grivescorbett@dpengineering.org
Team 1717, http://dpengineering.org
Unread 16-03-2009, 16:49
Spark The Ancient
along with the energy chain, what reason(s) did ya'll use toothed belts throughout your robot? and what design elements did you have to change to work with or around them? I noticed there is an idler wheel on every length of belt, is this what tensions the belt? could you have gone with thinner and less bulky belts in some places?
Unread 16-03-2009, 17:09
LBseale's Avatar
LBseale LBseale is offline
Still love 1717
FRC #1923
LBseale will become famous soon enough
In the past we have used chains exclusively, but have grown tired of the pain of tensioning them. You can tension a chain when you put it on, but it stretches out and you have to retension it. Not having an elegant solution to this problem that we could design for, we decided to try belts this season.
The belts turned out to be a great idea. They never change in length, which is a blessing and a curse. The blessing is that, once they are in, you never have to touch them again. The curse is that it can be difficult to get the right spacing between pulleys. This problem was easily solved for us by Solidworks' belt feature, which allows you to find out the distance between pulleys given a fixed belth length. Using this, we could use belts on the whole robot.
The idler wheels on the drivetrain are indeed for tensioning, and they serve to give the belt more surface contact with the drive pulleys for a more robust system. The ones on top give the turret a greater range of motion, since the belt is just riveted to the lazy susan.
I guess we could have gone with thinner belts, but they wouldn't have been as strong. We chose this pitch type because it allowed us to make the spacing in the wheel module as tight as possible, then used it throughout the robot.
In the end, never having to break and tension chain has been great. The computer modeling makes using more modern power transmission much easier. This is also the quietest robot we have ever built, without the clank and clatter of metal chain on metal sprockets.
Unread 16-03-2009, 17:29
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Can you tell me what pitch belt you went with? Also would you use belts in a 2 speed drivetrain with high traction wheels?
Mentor 2415
Unread 16-03-2009, 19:45
LBseale's Avatar
Still love 1717
FRC #1923
We used 5mm HTD belts. Yes, I think we would try to figure out a 2 speed belt transmission in a regular game. It sounds pretty crazy to me, but if we could figure out this drivetrain, I'm sure we could do it.
Unread 16-03-2009, 20:12
AKA: Sean
Where did you buy the 5mm belts? I am looking and sdp-si does not sell them. I am putting the finishing touches on a wooden framed 6wd high traction 2 speed, belt driven drivetrain. Right now I am looking at polycarb XL pullies and XL timing belt.
I was really asking would you use belt instead of #25 chain in a 6wd drivetrain with 2 speed transmissions and high traction wheels?
Mentor 2415
Unread 16-03-2009, 20:33
LBseale's Avatar
Still love 1717
FRC #1923
We got our belts and pulleys from our friend the BBman.
http://www.bbman.com/index.html
I think we would use belts, since we like how easy and quiet they are, but I'm not sure. That will be up to next year's team.
It looks like we both got into Looking Forward's post. 17** ftw.
http://www.chiefdelphi.com/forums/sh...threadid=75906
Unread 16-03-2009, 20:52
AKA: Sean
Thank you so much. That looks like a great store and we will probably order parts from them in the future.
I saw the Looking Forward post. I'm so excited that we have received so much notoriety but I wish we would have earned a spot to the Championship. There's just so much luck involved in this game, and this year even more than ever.
I would be really curious to see which one of our bots would win head to head. You have the killer swerve, but we have the dual fans...hmmm. I think we need to have a competition.
After watching your video its crazy how similar our robots are. I think we should just build together. HAHA
Mentor 2415
Unread 16-03-2009, 21:38
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
Hey 1717, first off I love your robot......It impressed me the most at the LA Regional, and I had the honor to be allianced with you guys.....and the curse of also being allianced against you, haha.
What drive/steering system are you guys using? The control looks REALLY nice and it has a 'creepy' glide factor to it when in operation.
Also, what happened at the last match with your turret? It looked to me as if the computer went insane.
Will you guys be going to any other regionals? If so, good luck, and we hope to see you at Atlanta! (providing we get our funding....)
Unread 16-03-2009, 21:54
GabeRC1717's Avatar
Team Role: Student
We have a swerve drive system where all of the wheels rotate, two left wheels and two right wheels rotate and drive together. The control is vector drive, where the joystick is angle and magnitude, the driver also has a traditional skid steer input. This combined with our traction control gives very good control.
In our last match we sustained a very large impact, and it caused the power connector to our analog breakout to come lose, disabling our robot.
We will be at Davis next weekend, thank you and we hope to see you in Atlanta as well!
Gabe
Unread 16-03-2009, 21:59
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
That is one sexy robot. It looks like you guys put a lot of effort into organizing the various systems of the bot so they work fluently together and in a very efficient and lightweight manner. IMO that robot looks worthy of a design award. go 1717!
(pardon my ignorance, but were you the guys with the vacuum bot last year? or was that 1771? so many 1's and 7's )
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 16-03-2009, 22:01
Drwurm's Avatar
Electrical Alumni
Originally Posted by Uberbots View Post
(pardon my ignorance, but were you the guys with the vacuum bot last year?)
1717 had an incredibly effective, yet simplistic, lift-bot last year, not a vacuum bot. There should be shots of it floating around.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
pic: Team 1717 Lift 2 rsilverstein Extra Discussion 8 19-04-2010 07:57
pic: Team 1717 Lift 3 rsilverstein Extra Discussion 9 28-03-2007 15:38
pic: Team 1717 Panel rsilverstein Extra Discussion 3 27-03-2007 15:55
pic: 1717 at the San Diego Regional 2007 Joe Ross Extra Discussion 6 27-03-2007 14:17
pic: 157 and 236 King of the Hill in the finals CD47-Bot Extra Discussion 3 16-03-2003 13:03
