Go to Post Read the rules. And then read the rules again. Then, get together as a group and read the rules together. - Knufire [more]
Unread 15-03-2009, 22:12
Chaos in a Can Chaos in a Can is offline
Joel Spadin
FRC #1736 (Robot Casserole)
Chaos in a Can is an unknown quantity at this point
Send a message via MSN to Chaos in a Can
Re: compiling speed-a few ?
You should be able to use the calibration file idea without running into the aforementioned problem.
You could load your main project that uses the calibration file as the startup application, then use a button on the front panel of a vi to save the current settings to the calibration file. Running the debug version should allow you to change the calibration file without rebuilding the startup application.
2006 Xerox Creativity Award
2007 General Motors Industrial Design Award
2008 Judges' Award
2009 Chrysler Team Spirit Award
Compiling Files Gherkinman Inventor 4 19-02-2008 21:55
Compiling error AdamHeard Programming 2 30-01-2008 09:57
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Compiling Error DustinB_3 Programming 1 12-02-2007 18:06
Compiling problem Anime-niac_2.9 VEX 4 19-10-2006 16:13
