Go to Post I (personally) am not involved in FIRST because I want to win (of course, that would still be nice ;) ). - pogenwurst [more]
Unread 03-15-2009, 10:50 PM
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
pic: The chances we take!
have your teams done anything crazy this season like put a cRio inches away from a bandsaw??? ...Sometimes these things just come up
Unread 03-15-2009, 10:52 PM
MPG's Avatar
MPG MPG is offline
Tutu Man
AKA: Michael
FRC #1259 (Paradigm Shift)
Team Role: Electrical
MPG is an unknown quantity at this point
Re: pic: The chances we take!
Being on the electronics subteam on my team, this is about the time that I would have had a heart attack knowing that the cRIO is that close to the saw blade.
Team Robot Names
2010 = Oswald
2009 = Black Magic
2008 = Barnaby Rover
2007 = Z
2006 = Dilbert
2005 = Oder
2004 = Gerry
Unread 03-15-2009, 10:53 PM
gorrilla's Avatar
gorrilla gorrilla is online now
AKA: adam spears
FRC #1557 (12voltbolt)
Team Role: Driver
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
you couldent cut it from the other side?
Adam Spears
2010: Florida Regional Finalists.
2010: Goveners Award.
2010: Florida Regional Judges Award.
2010: UL Saftey award.
2009: Florida Regional Chairmans
2009: Rockwell Automation Innovation in Controll Award.
klrswift klrswift is offline
AKA: Kevin Swift
FRC #0910 (Foley Freeze)
klrswift has a spectacular aura aboutklrswift has a spectacular aura aboutklrswift has a spectacular aura about
Send a message via AIM to klrswift
We have a little saying on our team.
"Don't worry, we'll fix it in software."
Unread 03-15-2009, 11:06 PM
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
OK so plus 10 points for style, but minus several million for intelligence . .
but I do like the cable management job you did, very spiffy.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 03-16-2009, 12:39 AM
Justin_B's Avatar
Justin_B Justin_B is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
Justin_B is an unknown quantity at this point
there is a good lesson to be learned here, measure twice, cut once, or something like that. And why didn't you cover the electronics, to prevent the dust from getting in. we had to do some similar modifications to our electronics board also, but that was because we forgot to mount a speed controller.
Unread 03-16-2009, 12:44 AM
AKA: Samir Shaikh
FRC #4329
we did shave off from the opposite side as far as we could. also though, We did blow the whole thing off with compressed air for about 10 minutes and made sure to check for any shavings in the system before powering up. It was kind of getting crunch time when we did this, but we did take as much caution as possible while doing it... (should of thought of covering the crio ports though... oops )
Unread 03-16-2009, 12:55 AM
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
Dear god is there no other way other than to put that cRIO that close to the saw blade? Your electronics captain must have had a heart attack, and even after being revived had another one.
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
Unread 03-16-2009, 12:57 AM
AKA: Samir Shaikh
FRC #4329
lol... the angle kinda makes it look closer than it is. Once we got that close, we had backed it out and then we used a dremel tool. we had about 4 people guiding it through and watching it very closely..
and if you notice, the blade could not touch it because it's guard was just above the lexan so nothing besides the lexan could touch the blade.
Unread 03-16-2009, 07:43 AM
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
The other side wasn't the problem!
Hi!
Unread 03-16-2009, 08:05 AM
You know I have to ask this! The modules pull out of the Crio and there should be only a few attachments to mount the Crio on the board. It would seem to me that about five minutes of caution could prevent a potentially costly error. If you had used tywraps to hold the Crio in place, you could have had it out of the way in a less than a minute.
Unread 03-16-2009, 08:29 AM
This is a joke, right?
Right?
It better be a joke. Two screws and two small cables, all easily removed, are the only things connecting the cRIO to the panel. Keeping the cRIO there and totally unprotected while running it through a band saw is, to put it bluntly, stupid.
Unread 03-16-2009, 10:33 AM
Right?
I deleted a similar post draft of mine because I couldn't find a polite way to say it. Don't do this. This is why we have to label coffee as hot.
Unread 03-16-2009, 12:24 PM
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Lol the sawdust can't be too good for the connections. You should've removed the cRio first.
Unread 03-16-2009, 05:04 PM
AKA: Samir Shaikh
FRC #4329
pic: The Referees gang up to make us take them off kevin.fort Extra Discussion 1 03-28-2007 10:17 AM
Take some time, read the manual, take a breather, and calm down. Elgin Clock General Forum 8 01-08-2006 06:35 PM
Tips to increase your chances of winning an award at the nationals thoughtful Championship Event 4 04-03-2005 04:32 PM
What speed do you surf the net? Take the test! Elgin Clock IT / Communications 77 03-30-2005 04:28 PM
Chances at UTI Matt Attallah Career 0 01-28-2003 08:20 PM
