Go to Post Whether or not your team has the technical mentors, as long as your kids are still inspired by the adult technical mentors of other teams, and get the picture that we're trying to portray in this program, the best that you can do is the best you can do. Do it, and be proud of your results. - Beth Sweet [more]
Unread 16-03-2009, 14:36
Chris is me's Avatar
AKA: Pinecone
Re: Modifying
Originally Posted by JAZAD1 View Post
Make sure though that all modifications are up to date on the rules, even though the dumper sounds good double check before you do anything to it. Also make sure that all of your parts that you are using to change it are under 45lbs so that you can use them all.
I believe if the part is not fabricated when you enter the pits that you can use it regardless of weight, right? I'm not sure, thankfully we didn't need to add more than our carrying allowance to our robot this year.
Personally I would make the change if you can before being inspected so you don't have to go through the whole thing twice.
[OCCRA]: Modifying Shafts tdlrali OCCRA Q&A 1 30-09-2006 14:08
modifying parts? firstborn Motors 12 20-01-2006 14:35
Modifying Motors Gun Technical Discussion 2 27-02-2003 15:11
modifying sprockets gail OCCRA 3 05-10-2002 12:13
Modifying Casters Jim Meyer OCCRA 1 05-10-2001 21:15
