Go to Post If it were easy it wouldn't be worth triple the points, right? - SenorZ [more]
Unread 02-03-2009, 23:27
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
Re: Calling All Drivers
Know what you're going for. Don't just drive around hoping to end up behind someones trailer, hone in on someone and don't give up becuase you think you see a better opportunity elsewhere.
I know our machine well, I know what its capable of, and I know how the traction control will effect my driving, and I was still making mistakes early on in qualifying matches.
It takes longer than you probably think to turn your robot around, even 90 degrees, and take off full speed in one direction. Frequently I was finding that I would "give up" on following a robot to dump into, becuase I thought I saw, in my mind, a better opportunity to score which was usually on a robot moving in a different direction than our robot was. I wasted a lot of time turning around and if I have learned one thing from the GSR, it would be to stick to a target, and only change targets if you're completely sure you won't waste too much time doing so.
Unread 03-03-2009, 22:27
nukelear1991 nukelear1991 is offline
AKA: Mike Poff
FRC #0858 (Delphi Demons)
Team Role: Tactician
nukelear1991 is on a distinguished road
Exclamation Re: Calling All Drivers
Be patient and dont let the stress on the field go off the field, a whole team can fall apart because of one ticked off driver.
2009 Lansing District Event Champions
Unread 04-03-2009, 12:34
Gin Gin is offline
AKA: Jacob
FRC #0291 (CIA)
Team Role: Driver
Gin is an unknown quantity at this point
Send a message via AIM to Gin
The main thing that you have to watch out for is which dumpers and human players have balls. This game this year is crazy and you need to have tabs on who can unload and score for you. Watch out to see where the empty cells go so you can get on the other side of the field.
2008 Chairman's Award (Pittsburgh) & Human player
2009 Coach
2010 Chairman's Award (Buckeye) & Driver
Unread 04-03-2009, 13:31
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The coach, more than ever, needs to have good field vision. They need to keep track of everything from where robots are moving to, to what human players are doing, to where the empty cells are going. There's alot to keep track of in this game, it's almost as if you need to split it all up amonst your entire alliance. You also need to figure out if the opponents have a better strategy than you, and adjust yours accordingly on the fly. That's probably the toughest part.
2017 Scoring Model
CAD Library | GitHub
Unread 04-03-2009, 14:32
BigWhiteYeti's Avatar
BigWhiteYeti BigWhiteYeti is offline
FIRST class flier
AKA: Patrick M.
FRC #0857 (Superior Roboworks)
Team Role: Driver
BigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura about
With the driving as slow as it is this year, your decisions will only start to happen a second after you hit those sticks. It takes time to build speed, to stop, or to turn. Anticipate your next move and start to turn or stop a half second before you want to. And mostly, dont panic and gun your wheels. Spinning out leaves you vulnerable and incapable of turning.
-you're fired
Unread 04-03-2009, 20:11
Dragonscythe261 Dragonscythe261 is offline
FRC #2068
Dragonscythe261 is an unknown quantity at this point
Hi there. I agree- the trailer is a great tool. It's one thing to have complete control of an unhitched bot and something much more magical to have complete control with a trailer. If you can do this, you can use the trailer to reverse right to where you want to be- this is both impressive and unexpected so you get the kudos and an easy attack. The driver needs to be conscious of the entire field but still rely on his/her coach. Most importantly though, stick to the strategy unless your coach demands otherwise.
Unread 04-03-2009, 20:28
GillSt.Bernards's Avatar
GillSt.Bernards GillSt.Bernards is offline
AKA: Amanda Cullen
FRC #2458 (Team Chaos)
GillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to all
Send a message via AIM to GillSt.Bernards
The traction was a lot less of a problem then I anticpiated it to be. Just watch to not get pinned by an opposing station
"A Dream is just a dream, a goal is a plan with a deadline" - Fortune Cookie-
"Life is a runaway train you can't wait to jump on"
-Sugarland (Already Gone)-
Unread 09-03-2009, 11:08
wcamp1742 wcamp1742 is offline
AKA: Will Campbell
FRC #1742 (Shockwave)
Team Role: Driver
wcamp1742 is on a distinguished road
Unless you're being hunted by another bot, just do what you do best. You don't always have time to consider what the other 5 bots are doing as the driver so stick to your strategy. Listen for your commander to tell you when to take evasive action and COMMUNICATE! Talk to your co-driver and encourage your commander to talk to your other alliance members during competition, especially during elimination rounds. We got shafted once by our own alliance member when they pinned us in the last 20 seconds by mistake. They weren't listening so they didn't hear us yelling at them to back up.
2009 OKC Regional Champs (1561/2004 SHOCKDUCK Alliance)
2009 Rockwell Automation Innovation in Control Award Winner (OKC Regional)
2009 General Motors Industrial Design Award (OKC Regional)
2009 Dallas Regional Semifinalists
2009 Dallas Gracious Professionalism Award
Unread 09-03-2009, 16:30
HighLife's Avatar
HighLife HighLife is offline
FRC #0245 (Adambots)
HighLife will become famous soon enough
Send a message via AIM to HighLife
Keep moving and stay away from the good human players, especially in the last 20 seconds of the match.
AdamBots.com- Winner of 7 Best Website Awards!
Unread 09-03-2009, 16:51
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Strategize.
I have seen more upsets in the last 2 weeks than I have in the last 3 years.
Lunacy is a fair deeper game then many of us realized in the early days of build. A good strategy, more so than a good robot, is what wins matches. We've seen some of the most powerful teams fall to teams that we knew nothing about 6 weeks ago and it can all be contributed to strategy.
Go out and meet your alliance partners before every match! Learn what they can do and learn what your opponents can do. Then from there try to play the game as smart as possible. Don't take unnecessary risks because they can be your downfall.
-Dustin Benedict
Unread 09-03-2009, 20:50
Hanna2325's Avatar
Hanna2325 Hanna2325 is offline
Programmer/Driver
AKA: Hannah
FRC #2177 (Robettes)
Team Role: Driver
Hanna2325 will become famous soon enoughHanna2325 will become famous soon enough
Send a message via AIM to Hanna2325
Move
Really consider if the points you are going for are = to the points you can loose. It isn't worth getting stuck next to a robot that is about to pour twenty balls into your trailer just to score one ball, for example.
If you can empty a ton of balls at once do it before trying to get a single 10pt b/c a lot of small balls add up faster, for the most part -- a lot of this depends on ur robot design of course
don't forget about ur human player (they've been a big determiner from a ton of points scored to tie braking fouls...)
And if ur robot is broken, don't try and run it, it is easier to move/protect a trailer than a trailer attached to a dead robot (and ur alliance will thank u)
Be sure to strategize with alliance members before round, some teams might need to closer work together to complete high scoring tasks than others and if picking an alliance take into account human players and the compatibility of ur robots not just pts scored (although this is important too).
But really, for most of the driver stuff it depends what you are comfortable with and ur robots capabilities. I'd say the safest thing is to do what u know best!
that light is NOT yellow, its orange! Where is the yellow light?
:1..2...3...BEAST!:
Unread 16-03-2009, 20:54
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
In my opinion after this second week, and to answer the long asked question, shooter beats dumper.
Unread 16-03-2009, 21:15
JM987's Avatar
JM987 JM987 is offline
High Rollers
AKA: Josh Mauro
FRC #0987 (High Rollers)
Team Role: Driver
JM987 has a spectacular aura aboutJM987 has a spectacular aura aboutJM987 has a spectacular aura about
Send a message via Yahoo to JM987
keep moving, stay away from opposing fueling stations and outposts, don't get pinned, and if you do fight against the robot.
Check Out Our Website!
HERE!
- 2009 Las Vegas Regional Winners (thanks to 1622 and 1013)
- 2009 Las Vegas Regional Chairman's Award Winner
- 2008 IRI Winners (thanks to 330, 67, and 68)
- 2008 Archimedes Division Finalists
- 2008 Las Vegas Regional Chairman's Award Winner
- 2008 Las Vegas Regional Winners (thanks to 39 and 1013)
- 2008 San Diego Regional Finalists
- 2007 FRC World Champions (Atlanta thanks to 190 and 177)
- 2007 Newton Division Winner
- 2006 Las Vegas Regional Winner
- 2005 Las Vegas Regional Winner
Unread 17-03-2009, 14:42
Chris is me's Avatar
AKA: Pinecone
Don't get hit.
Have a plan. Take your three robots, take the other three, sit down before queueing and go "which one can score the best? Which one is most mobile? which one is likely to not do anything?" Take your mobile members and make them pin people, take your high scorers and have them handle balls, and keep the powerhouses in check as you try and juggle this game.
Unread 17-03-2009, 14:54
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
dont give up if the odd's are'nt good
3 moderately good robots can easily defeat a superior alliance with the right strategy......
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Calling All Homeschoolers Penny Team Organization 1 26-04-2005 10:51
Calling All Parc Mascotts Mascott222 Off-Season Events 10 27-04-2003 21:57
Calling all Actors archiver 2000 0 23-06-2002 22:49
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
Calling all Tigerbolt Chatters - And All Newcomers! Lora Knepper Chit-Chat 9 11-07-2001 18:09
