Go to Post Edison was once asked "how do you come up so many good ideas?" to which he responded "for every good idea, I have 99 bad ideas first." - dlavery [more]
Unread 15-03-2009, 22:03
Birdlives's Avatar
Birdlives Birdlives is offline
FRC #2337 (EngiNERDs)
Birdlives is an unknown quantity at this point
Saving and Retriving data to the cRio in Labview
I need to save data to the cRio and later load it on to a computer.
I am relatively new to the programming world, so please bear with me, as I have only been using Labview for about a year.
Many thanks
Unread 16-03-2009, 07:38
Re: Saving and Retriving data to the cRio in Labview
To save it, use file I/O functions, perhaps look at examples if you get stuck.
To retrieve from the computer, I'd use an ftp client. If you don't have a good one, you can type ftp:///10.xx.yy.06 into the address bar of an explorer window. Navigate to the location you saved the files and drag the file back to the PC file system. Just beware of caching with the Windows Explorer based ftp. It usually works, but sometimes shows you stuff that isn't really there.
Greg McKaskle
Unread 16-03-2009, 15:18
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
ftp://
not
ftp:///
Watchdog.Kill();
Unread 16-03-2009, 21:26
Thanks.
Greg McKaskle
Data delay between Crio and DS Tom Line NI LabVIEW 9 17-02-2009 08:40
Saving files on the cRio Bomberofdoom NI LabVIEW 8 16-02-2009 08:33
Vista and Labview to CRio Skyman7 NI LabVIEW 0 13-02-2009 18:42
Capture Data from the cRio goodsky Programming 2 13-01-2009 21:27
Students build SEGWAY in 3 months using Labview and the cRIO neutrino15 Programming 31 27-04-2008 22:08
