Go to Post What's the reason for having a rule if it's not enforced? - jpsaul7usa [more]
Unread 16-03-2009, 18:39
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
pic: Team 1024 Before and After
Unread 16-03-2009, 18:40
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Re: pic: Team 1024 Before and After
Which preformed better? What was the biggest advantage of each? Sweet looking bot both ways!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 16-03-2009, 18:47
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Go dumpers!
Very cool looking robot.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 16-03-2009, 18:53
joshsmithers's Avatar
joshsmithers joshsmithers is offline
go team 4910! get that FLL!
AKA: username-ers=myname
FRC #0587 (Hedgehogs)
joshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of light
Awesome! I see we weren't the only team to change from shooter to dumper. Rather than one hour to change over, it took us 6 hours. We were very satisfied with our new dumper. The most noticeable change was that our scoring success rate went up.
Questions: It looks like you use a spinning bar. What motor do you have turning that? Also, what is the height of the bottom of your hopper? (Ours was 45" high.)
Genius is 1 percent inspiration and 99% perspiration, which is why engineers sometimes smell really bad.
Unread 16-03-2009, 18:59
Meredith Novak's Avatar
Meredith Novak Meredith Novak is offline
no team (Arkansas FIRST)
Meredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond repute
Nice job. I was very happy to see 1024 in the hunt in Wisconsin!!!
Unread 16-03-2009, 19:16
AKA: Allison Phelps
Thanks Meredith!
The shooter ended up ranked 28th at Midwest.
The dumper ended up ranked 6th at Wisconsin.
The advantage of the shooter was ideally that it could shooter in any direction.
The advantage of the dumper is the ability to score many balls quickly. The feed to our shooter was a bit slow so the dumper is much faster. Our dumper scored consistently while our shooter did not.
We also had issues with the camera code bogging down the driving code and creating lag at the Midwest Regional. Removal of the shooter and turret code gave our driver much more control.
We brought our dumper in as a 19 lb assembly ready to be riveted on to our hopper (matching hole pattern in both top plates). Allowing for a quick efficient change.
the bottom of our hopper is at approx 48" off the ground. Our robot as shown at Wisconsin in 59" tall. The spinning bar as you call it is a .035 Wall Aluminum tube cover in velcro, the motor running it is the banebot motor (RS-545) with a 5:1 gear box
Unread 16-03-2009, 19:30
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
I noticed the only real problem you guys seemed to have with the new design was balls seemed to get caught up in the initial intake area off of the ground. I'm glad you figured out a way to be more effective and you guys did great at Wisconsin. Do you guys know if you are going to Atlanta yet?
Unread 16-03-2009, 19:58
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Nice job... great improvement! It's good to see 1024 back in the hunt!
-p
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Unread 16-03-2009, 20:01
JasonV JasonV is offline
FRC #0217 (ThunderChickens)
JasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud of
Send a message via AIM to JasonV
I was wondering how you were gonna change it up from midwest, and I like how the robot looks like it was meant to be built for a dumper. Nice job and good luck
Unread 16-03-2009, 20:20
william.walk's Avatar
william.walk william.walk is offline
william.walk is an unknown quantity at this point
The jamming problem at the intake was fixed before the elimination rounds. Beleive it or not the jaming problem at the intake of the robot (bottom) was caused by the switch from shooter to dumper. The top plate for the dumper was to flimsy and allowed the spinning brushes running the hopper to lift up. That in return allowed a set of bevel gear under the robot to seperate and the intake rollers would stop turning.
Currently we have no real plans for going to Atlanta. Basically the only way we would consider it is if we somehow win this week at Boilermaker.
We are still currently searching for something that resembles traction control with atleast a little speed for the robot. If you noticed at Wisconsin, we were slow moving and struggled greatly when put in a pushing situation.
Unread 16-03-2009, 20:28
Fans? If you can find the weight for it... They seem to give teams a bit of an edge.
Unread 16-03-2009, 22:45
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Do the balls feed up from the bottom to the hopper or do you have to throw them in?
Sorry, I didn't get to watch the WI webcast...
Good luck at BMR! I'll be there on Saturday.
Go Teams!
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 16-03-2009, 23:12
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
The balls feed up through the entire spiral hopper, then up to a top storage area for a few balls.
Or, at least that is how I saw it at Wisconsin.
Unread 16-03-2009, 23:24
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
WHILE YOU WERE OUT: FRC
*driver comes back in the shop* .......OHMIGAWD WE HAVE A DUMPER!!!!
other team member- yes, and it only took ONE HOUR!
*driver starts crying* You guys rock... *goes over and hugs the robot*
forgive me, I am tired
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 17-03-2009, 06:18
AKA: Allison Phelps
Q,
They feed up through the spiral just like they did at Midwest. Once they get to the top there is poly-cord stretched between two tubes to lift the balls up in to the upper hopper. The upper hopper has poly-cord running along the bottom to move the balls forward while the top roller spins backwards to keep the balls in until it is time to dump.
Stop by on Saturday and we can give you a demo if you want.
Allison
pic: 1024 just before first finals match at Midwest Regional Qbranch Extra Discussion 3 14-04-2008 22:20
Before and After i_am_samus Games/Trivia 7 13-01-2008 10:17
pic: 166 Before and After: All in Two Hours Dan Petrovic Extra Discussion 3 30-06-2006 16:43
pic: 1675 Before and After Kevin Kolodziej Robot Showcase 4 23-02-2005 13:22
pic: Team 1595 wiring before and after!!! L@@K sgsdragons Robot Showcase 6 11-02-2005 19:25
