Go to Post One of our electrical engineers would bring his kids in every so often, so they could actually see their dad during build season. - Karthik [more]
Unread 17-03-2009, 06:59
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Live Video on Dashboard
Originally Posted by buchanan View Post
Is there an API for compression?
We used the Flatten Image to String VI, which allows you to specify a compression algorithm (PNG/JPG/TIFF/BMP - but TIFF and BMP probably wouldn't be suited for this application) and in the case of JPG, a quality setting which essentially controls the compression rate/lossiness (those who are familiar with the JPG format are aware of this setting).
This produces a string which we converted to a byte array using the usual String to Byte Array function, then packetized to send over the network.
The one disadvantage to this approach is the compression algorithm takes a little time to run, but this was compensated for by running parallel while loops with 1-element queues to pass the data around.
Unfortunately I won't have access to the code for another week or so, but I can post the code then if anyone is interested.
I do like the idea of just passing through the images from the camera. [writchie] I think you hinted at this, but does the Axis cam supports changing JPEG quality levels?
--Ryan
FRC 766, 2015-, Mentor
LabView dashboard/live telemetry smcmahon National Instruments LabVIEW and Data Acquisition 8 19-01-2009 19:45
New Video Blog Entry: "Video from Live LabVIEW Session for FRC Competitors in Toronto LVMastery NI LabVIEW 0 13-12-2008 08:09
Labview Video Tutorial? Dashboard Chris_Elston National Instruments LabVIEW and Data Acquisition 21 25-01-2008 00:29
Live video with Kit Camera BobcatProgramer Electrical 10 11-01-2005 10:43
Live Action Video - 3D Animation Combination Ryan Dognaux 3D Animation and Competition 18 06-08-2003 19:33
