Go to Post a Victor is a Victor is a Victor. - Billfred [more]
Unread 10-03-2009, 13:21
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
need help with rules
is it allowed to move the shooter during the game out of the maximum limits--> width one <-- (pay attention not in the default case )
Unread 10-03-2009, 13:29
Re: need help with rules
I'm not sure exactly what your question is, but <R11> gives a very clear answer. At no time during a match may the robot (excluding the bumpers and trailer hitch) exceed the 28"x38"x60" dimensions.
Unread 10-03-2009, 13:31
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
No, no part of your robot may extend outside your bumper perimeter at any time during a match. See Rule <R16>.
Unread 16-03-2009, 21:24
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
<R11> At the start of, and during, the MATCH the ROBOT shall fit within the orthogonal dimensions
listed below:
|Dimension 1 | Dimension 2 | Dimension 3 | Maximum |
|(Horizontal) | (Horizontal) | (Vertical) | Weight|
|28 Inches | 38 Inches | 60 Inches | 120 Pounds|
|(71.12 cm) | (96.52 cm) | (152.40 cm) | (54.43 Kg) |
A. Exception: solely for the purposes of determining compliance with the weight and
volume limitations, these items are NOT considered part of the ROBOT and are NOT
included in the weight and volume assessment:
• The 12V battery and its associated half of the Anderson cable quick
connect/disconnect pair (including no more than 12 inches of cable per leg, the
associated cable lugs, connecting bolts, and insulating electrical tape),
• BUMPER assemblies that are in compliance with Rule <R08>,
• The TRAILER,
• The Trailer Hitch (as defined in Rule <R18>),
• The OPERATOR CONSOLE.
This is what I believe the robot must comply with. During Finger Lakes Regional I was told during practice matches that if I didn't tuck the battery cable back in so that it doesn't go past the start of the bumper that I would be disqualified, given a yellow card that would turn into a red card before the first 30 seconds was up. So I would keep all dimension within the original constraints also to be 100% sure I think you should review Section 8.3.2 regarding general robot design, to make sure your robot fits all criteria
Unread 17-03-2009, 13:57
Bob Steele's Avatar
AKA: Bob Steele
This brings up an interesting issue. I hesitate to even bring it up...but here goes. After nearly EVERY match...there are bits and pieces of robots that are left on the field.
If a referee sees something come off a robot (unintentionally) during the course of play...wouldn't it be incumbent on him/her to give a penalty for the robot being outside of its orthogonal dimensions?
I won't be asking Q and A about this... it just occurred to me that ... if referees are giving penalties when a battery shifts and the cable sticks out... then why not when a part comes off?
just asking ....
I guess if you lost a screw you could just have the robot squat over it like an egg until the end of the match to avoid a penalty....
Unread 17-03-2009, 14:39
Chris is me's Avatar
AKA: Pinecone
I was under the impression that when the robot parts leave the robot, they are no longer controlled / touching the other robot parts and are thus themselves not robots.
Unread 17-03-2009, 14:46
Bob Steele's Avatar
AKA: Bob Steele
That sounds good to me...
Unread 17-03-2009, 14:55
The usual interpretation: when a part comes off, it becomes field debris and is no longer part of the ROBOT. If the part is still hanging on, however, it can draw a penalty for causing the robot to extend outside the permitted dimensions.
Need help with Variables ? David Bryan Programming 5 23-02-2004 07:42
need help with programming magical hands Programming 1 11-02-2004 22:12
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Need help with C++ Tton Programming 7 04-11-2003 19:15
Need Help: Simplified 2002 Rules suitable for Display Mark Hamilton General Forum 2 08-12-2002 14:53
