Re: [FTC]: Defense vs. Gracious Professionalism
Gracious professionalism is about respecting your opponent's, this doesn't mean you can't play with a good defense. That's sort of like saying that scoring a ton of points in one dump of pucks is disrespectful to your opponents because you're setting the bar way high. Defense has been a long time aspect to challenges and games of all kinds.
This strategy is great. Gracious professionalism should not stop you from using it. Some people may frown upon it saying that it may be unsportsmanlike. Personally our team has used the strategy of holding the opponents pucks and dumping them out of the field. This is a very useful tactic and i think it is a great strategy and not lack of gracious professionalism. Props to those who use the strategy to their advantage.
Keep in mind that your RP points are related to the amount that the losing alliance scores. So, if you are a strong scoring alliance and will likely score more than the opponent anyway, dumping their pucks outside the playfield actually hurts your standings.
The optimal would be for your team to win with a slim margin and high score. Sean |
It seems that many people confuse gracious professionalism/good sportsmanship with not doing things that are part of the game, such as blocking opponent robots and taking opponent pucks out of field play. But just like stealing the ball or blocking a shot in a basketball game isn't bad sportsmanship, blocking a robot or dumping opponent's pucks to help your alliance out isn't opposed to gracious professionalism; it's just another way of doing better than your opponent.
-Jonathan |
Wordat Nitro-Guy.
i've been wondering though, has any1 here scored their opponents pucks against a not so strong opponent to boast their RP points?
#7
Yup, combining that aspect with your defense strategy is the difference between just a high torque (or speed) squarebot and a winning defense bot.
#8
I don't know why, but this years challenge seems to need a lot more scoring to for your opponents than previous years. Though it isn't always. |
#9
) but it seemed that back then, even against a good scoring team the goals could swing things either way. Getting off the field this year simply does not compare, especially in comparison to the number of points that can be scored. And, especially for rookie teams, it's hard to build a decent scoring robot.In regards to defense, I think it's a fine strategy but against the majority of teams dumping pucks on the floor would be just as effective. I couldn't really justify the extra time taken to dump pucks outside of the field unless you were up against a robot that could pick up pucks from the floor really well. |
#10
but in the worlds, when you have good robot against good robot, i think the chance of scoring 2 pucks in auto is pretty remote seeing how every1's gonna be moving. you might be able to obstruct the other robot's first rack while you go for your second, but 1 rack in auto doesn't decide a game. but yeah if you get 2 racks in... then yeah.
#12
(But it still means that things will mostly be decided by autonomous. Which means that my team has a lot of work to do before Atlanta. ) |
#13
The other skill not much in evidence at regionals that could be key at Worlds is picking pucks off the floor. If the defensive auto strategies work there will be a lot of pucks down during auto.
#14
Another strategy I found was defensive, yet I, to be honest, think it is a "cheapshot" strategy:
In one of our matches, there was a robot's autonomous mode. We noticed it changed. Normally, the robot would just proceed and go forward. However, our robot had an autonomous that scored (Only maybe 4 or 5 robots at the tournament had a scoring autonomous). It seemed as if they knew how our autonomous mode worked, and they changed their code to go forward, then turn, then go forward, and "park" in our path. It threw us off by the way. |
| Gracious Professionalism | Lady Lightning | General Forum | 50 | 27-05-2009 20:40 |
| Let's Put the Professionalism back in Gracious Professionalism | Katy | General Forum | 30 | 16-03-2008 14:12 |
| Is it Gracious Professionalism to ... | ChrisH | General Forum | 10 | 31-03-2003 15:59 |
| Gracious Professionalism? | archiver | 1999 | 0 | 23-06-2002 23:04 |
| Gracious Professionalism | Brian C | General Forum | 0 | 29-04-2002 22:09 |
