Go to Post Team 233 cannot wait for the Florida Regional, but they have to because they have to build a robot or something first. . . - IbleedPink233 [more]
Unread 19-03-2009, 12:58
Re: pic: Right Round
Originally Posted by Jeff Pahl View Post
Lightweight, stiff, fairly strong, easy to work with. You can get it (or something similar) from most industrial plastic suppliers, or smaller pieces from your local sign shop. [...]It's not stiff enough to mount a cRIO though. It comes in a bunch of colors, too.
Depends on your thickness and support. It will support a cRIO if it will support a robot.
And yes, I have some pictures:
http://www.chiefdelphi.com/media/photos/27581
http://www.chiefdelphi.com/media/photos/27719
Team 330, 2007. Support: 1" thinwall aluminum tube on 4 sides, glued on, IIRC. Might also have a couple of bolts/rivets. Survived 1-2 regionals and up through Einstein semis, depending on exactly which panel. Also IRI and the Fall Classic, if I remember correctly. That stuff is tougher than you're giving it credit for. Just use a couple of largish washers when you put a bolt through so it doesn't collapse as badly as it would under a point load.
fitting a round rod in a round hole GMKlenklen CAD 12 23-08-2009 01:20
pic: Right Frame IndySam Extra Discussion 11 18-01-2008 22:37
pic: CD Photoshop Round 2 Michelle Celio Extra Discussion 11 20-04-2006 15:57
pic: Swing yer parders round n' round! Koko Ed Extra Discussion 8 26-05-2005 13:07
pic: Right Side view CD47-Bot Robot Showcase 2 03-03-2003 15:26
