Go to Post If you let me borrow your time machine, there are various ways to fix this. But mine is on the fritz. - Greg McKaskle [more]
Unread 24-02-2009, 14:46
Bob Steele's Avatar
Bob Steele Bob Steele is online now
AKA: Bob Steele
Video recording at Events
Could anyone enlighten me on the best way to capture the video feed at events for later use? A few years back we just used an old VCR to do this but I am sure there are better ways and better equipment to do it..
I could use some suggestion on how to do this and the equipment that has worked in the past for teams.
What do we need???
thanks in advance!!!
Unread 24-02-2009, 17:00
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Video recording at Events
What do we need???
There are numerous ways to record the video. You could use a DVD recorder just remember to mark the DVDs. You could use something like this and a USB flash drive or external harddrive. You could also build a computer with a video capture card and some software.
Unread 24-02-2009, 19:44
Mark Rozitis
Posts: n/a
What do we need???
One thing I noticed at the GTR regionals in Toronto was the video feed had BNC connectors and audio was XLR connectors on the media feed board. Regardless of record device you are using, be it a DVD recorder or whatever a good selection of BNC to RCA adapters and XLR to RCA adapters, male/female and a couple of barrel connectors and gender changers can't hurt. In Toronto I buy that stuff at Sayal electronics.
Now I am not sure how good acsess is to place record equipment near the pool feed box, at GTR it was on the floor by the sound system area, for audio you can use something like the senhiesser G2 kit and you can be outside the venue and still get a signal but video you need to cable to the box.
So keep those things in mind. I work in news so I just grabbed the audio feed so I had the announcers voice loud and clear and then music loud and clear on my channel one and then my channel two was just the open camera mic.
video I shot with my camera of course so I didn't plug into the pool feed for that.
If they let you place you're record equipment near the box then you should be good to go, it should be composite video out but like I say the box I saw at GTR had all BNC connectors, female BNC connections actually.
Another important thing when connecting to any media pool feed box is to have earphones and monitor/check you're audio, the XLR ports on the box are mic or line level selectable but even then you may have to adjust you're audio input levels.
One mistake such as selecting line level and not checking can result in totally over modulated and unusable audio, or perhaps no audio, or audio with a loud buzz should a ground wire be off or something like that. In news I always check with earphones what I am recording......no exceptions.
Also, bring extension cord and duct tape to safety tape the cable to the floor, 120volt power to run you're dvd recorder might not be available right at the box, you may have to run a bit of cable a few feet.
mark
Unread 24-02-2009, 20:14
Jonathan Norris Jonathan Norris is online now
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Please take a look at the Wiki: http://www.firstwiki.net/index.php/2009_Archiving
Also take a look back at previous year's threads, there are multiple threads that talk about the best ways to record.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 24-02-2009, 20:26
ATannahill ATannahill is offline
AKA: Alex Tannahill
The only problem with your suggestion is on the wiki page we are redirected to an 11-page thread, I don't think anyone wants to go through 11 pages of I will record ____________ to find the diamond of information.
- Arizona North
Unread 19-03-2009, 22:31
Mark Rozitis
Posts: n/a
At Waterloo regionals today the audio from the provided sound board was just amazing good quality, all XLR connectors though so you need adapters to RCA or whatever the record device has for input, lots of video outputs as well and most were BNC but they had quite a few BNC/RCA adapters on hand.
I can't speak to the video quality as I shoot my own video but I patched my wireless into the sound board and the audio was phenomenal, the music and the announcers voice...just perfect.
My wireless is a senhiesser G2 kit and that goes on the XDcam.
it's good and probably will be the same at GTR
m
Video Recording Station Mufasa1111 Videography and Photography 9 13-03-2008 19:22
Should FLL and Vex events also be added to CD Events? Koko Ed CD Forum Support 2 03-10-2006 09:44
Webcast Recording Hiteak Championship Event 1 19-04-2006 20:58
Competition Recording trdragons204 General Forum 0 23-03-2005 10:56
Recording Equipment etoleb General Forum 5 13-03-2003 16:01
