Go to Post A drag racer can have all the output torque in the world, but it does no good on ice. - Paul Copioli [more]
Unread 24-06-2002, 02:56
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Has anyone succesfully programed the Gyro?
Posted by Edward Gilchrest at 03/30/2001 4:04 PM EST
Engineer on team #38, Nonnebots, from Nonnewaug High School and 9th Wave, Inc..
In Reply to: Has anyone succesfully programed the Gyro?
Posted by Anthony S. on 03/27/2001 8:50 PM EST:
: I'm a student from team #442, we initially planned to use the gyro to balance but on night before shipping decided it wasn't going to work therefore we built our famous "outrigger" A.K.A "pogo-stick". So I was just wondering if anyone knew how to work it, we tried forever to program it but never go it to. Please let me know if you did, I'm very anxious to see if anyone was able to get it working.
I am the president of 9th Wave Design, the sponsor for the Nonnebots, team #38. We have designed a gyro program that works successfully and consistently. The program is fairly simple. When we started designing the software we analyzed all the masses, wrote a program based on a PID algorithm (proportional, integral, derivitive) but found the loop speed to be too slow to properly manage it.
We then wrote a program that looks for the ramp to start tipping, immediately moves the robot backwards while calculating the angle and stops the pwm at a prescribed angle. This program also has a compensation for battery voltage, since the speed at which a particular pwm drives the robot is heavily dependent on battery voltage.
A very important aspect of the program is the fact that the operators clear the gyro counters and set a zero point while first moving up the ramp so errors don't add up.
The program is designed to balance the ramp without overshoot so it does not "close the loop" so to speak as a true PID algorithm would.
This program has worked well with one goal, two goals, and goals filled with balls without having to make any changes.
If anyone would like more info feel free to email me at egilchrest@9thwave.com
[IMG] code is Off
gyro code odin892 Programming 2 08-04-2003 14:50
Help with the gyro chip Team852 Electrical 1 10-01-2003 22:31
This Gyro is driving me crazy! archiver 2001 2 23-06-2002 23:35
Voodoo Gyro Chips... Ghetto_Child Technical Discussion 3 01-02-2002 16:39
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
