Go to Post A good teacher always needs to be a good student - Redhead Jokes [more]
Unread 21-03-2009, 11:16
Shadow503's Avatar
Shadow503 Shadow503 is offline
printf("\r\n Moo!");
Team Role: Human Player
Rookie Year: 1991
Shadow503 will become famous soon enoughShadow503 will become famous soon enough
Exclamation HELP: Robot Crash in Autonomous
I wrote some code for a simple table based autonomous mode, but whenever we ran it, the robot completely crashed (random motors will thrash around a split second before the thing finally dies).
I figure there must a seg fault caused by to the way I'm using a struct pointer, but I don't know enough C++ to get this coded the right way.
Anyone got a spare moment to look over the code? Thanks for your time!
auto_commands_2009.h:
//autonomous commands
#define AUTO_STOP			0
#define AUTO_DRIVE_4WHEEL	1
#define AUTO_DRIVE_PIVOT	2
#define AUTO_DRIVE_TANK		3
#define AUTO_DRIVE_CRAB		4
struct commands
	int steer_mode;
	double time;
	double speed;
	double angle;
struct Command
	int command;	//what command to run
	double param1;	//usually time
	double param2;	//usually speed
	double param3;	//usually angle
struct Command command_list_0[] = {	//DEFAULT - STAY STOPPED
		//   Command        parm 1     	parm 2   	parm 3
		//	Steer mode		Time(Sec)	Speed		Angle
		{AUTO_STOP,       	0.0,        0.0,     	0.0}
struct Command command_list_1[] = {
{AUTO_DRIVE_4WHEEL,       	1.0,        10.0,     	0.0},
{AUTO_DRIVE_PIVOT,         	1.0,        10.0,     	10.0},
{AUTO_DRIVE_4WHEEL,         1.0,        10.0,     	10.0},
{AUTO_DRIVE_PIVOT,         1.0,        0.0,      	0.0},
{AUTO_STOP,          		1.0,       0.0,     	0.0}};
autonomous_2009.cpp:
 * Call this method to drive
 * @param speed a double describing the speed		-15fps to +15fps
void Autonomous::procTable(int AutoMode) {
	// TODO Finish autonomous code
	//		static INT32 autoSec = (INT32)GetClock() + 1;
	curTime+= TIME_PER_CYCLE;
	currentStateTime += TIME_PER_CYCLE;
	struct Command *currentCommand;
	//set the commandlist
	switch (AutoMode) {
	case AUTOMODE_0:		//Auton mode 0
		currentCommand = command_list_0;
		break;
	case AUTOMODE_1:		//Auton mode 0
		currentCommand = command_list_1;
		break;
	case AUTOMODE_2:		//Auton mode 0
		currentCommand = command_list_2;
		break;
	case AUTOMODE_3:		//Auton mode 0
		currentCommand = command_list_3;
		break;
	case AUTOMODE_4:		//Auton mode 0
		currentCommand = command_list_4;
		break;
	default:
		break;
	//behave based on the current command
	switch (currentCommand[cur_command].command) {
	case AUTO_STOP:			//robot stopped
	default:
		reqDriveSpeed = 0.0;				// Requested Drive speed
		reqAngle = 0.0;						// Requested steer angle
		reqDriveMode = STEER_MODE_4WHEEL;	// Requested Drive Mode
		if(currentCommand[cur_command].param1 != 0 && currentStateTime >= currentCommand[cur_command].param1 ) {	//time to move on to next state
			if(cur_command + 1 < sizeof(currentCommand)) {	//there is another command to run
				cur_command++;	//increment to next command
				currentStateTime = 0; //move on to next state
		break;
Very Strange cRIO Crash Hunter1100 C/C++ 0 19-01-2009 16:39
HDD crash, need help recovering data! David Kelly IT / Communications 16 28-05-2007 23:25
PlasmaCam Crash Course Andrew Blair Technical Discussion 0 30-12-2005 21:48
Prom Night Crash Nate Edwards General Forum 5 28-05-2005 15:15
3dsmax5 Crash? yangotang Inventor 5 09-03-2003 21:17
